I want to generate the name of a include.h file from the name of the environment section in platformio.ini. Is that possible?
Example:
[env:ttgobeam]
platform = ${common_env_data.platform_espressif32}
board_build.partitions = ${common_env_data.board_build.partitions}
upload_speed = 921600
${common_env_data.lib_deps_all}
${common_env_data.lib_deps_gps}
${common_env_data.build_flags}
-include "src/hal/ttgobeam.h"
Is it possible to generate the filename “ttgobeam.h” from the environment name “ttgobeam”?
This way i could have a generic template in platformio.ini.
Thanks for the hint. So, how can i build the inlude path in platformio.ini using the environment variable? Still didn’t understand it.
What does it mean? Please rephrase.
I need something like
-include “src/hal/${env_name}.h”
Ah… Just use
-include “src/hal/${PIOENV}.h”
Works!
Wow, that was amazingly easy!
I love PlatformIO! Great!
@ivankravets
To make my platformio.ini even more generic, is it possible to have a common block in platformio.ini, that is used by several environments?
Like
[common]
[env: type1]
include $[common]
board = foo1
[env:type2]
include $[common]
board = foo2
sure.
Please have a look at the dynamic variables and adapt to your requirements…
http://docs.platformio.org/en/latest/projectconf/dynamic_variables.html
Hope this helps!!
