I want to have the possibility to step through my project, so I found the TeensyDebug TeensyDebug on GitHub. Everyone talking about this libary and how it’s implemented doesn’t seem to have any problems with it, however I do. For testing I used a simple blinky program so here is my code and platformio.ini:
main.cpp:
#include "TeensyDebug.h"
#pragma GCC optimize ("O0")
  debug.begin(SerialUSB1);
  pinMode(LED_BUILTIN,OUTPUT);
  delay(1000);
  delay(1000);
platformio.ini:
[env:teensy41]
platform = teensy
board = teensy41
build_type = debug
; See https://github.com/platformio/platform-teensy/issues/65
build_unflags = -DUSB_SERIAL
build_flags = -DUSB_DUAL_SERIAL
debug_port = COM8
debug_tool = custom
debug_load_mode = manual
debug_server =
debug_init_cmds =
  target extended-remote $DEBUG_PORT
  $INIT_BREAK
  define pio_reset_run_target
  interrupt
  tbreak loop
  continue
  end
  define pio_restart_target
  echo Restart is undefined for now.
  end
debug_init_break =
It even starts the Debugger, and stops during Initialization. This is the Output i get:
PlatformIO: debug_tool = custom
Print::print (base=16, n=<error reading variable: Cannot access memory at address 0x0>, this=<optimized out>) at lib\TeensyDebug-master\src\TeensyDebug.cpp:1134
1134	void dumpmem(void *mem, int sz) {
Ignoring packet error, continuing...
While the debugger is halting here, the program continues (LED is blinking), but no matter if I step over, into or continue, the program then stops at a breakpoint (LED stops blinking), however the debugger looks like it’s just running.
I have no clue on why it isn’t working. I tried pretty much evey trick some people gave ni forums and i even tried VisualMicro and it didn’t work either. So please tell me what i am doing wrong. Thanks in advance
