Gdb launch error
while launching debug, i am facing this issue
Failed to launch GDB:.pioinit:13: Error in sourced command file: COM13, No such file or directory.(from interpreter -exe console “source-pioinit”)
my .ini configuration is :
[env:uno]
board = uno
debug_tool = avr-stub
debug_port = COM13
;GDB stub implementation
jdolinay/avr-debugger @ ~1.4
  1. Is COM13 the right COM port for you Arduino?
  2. Have you tried setting debug_port = \\.\COM13 instead? COM ports > 9 need this format instead in Windows (source).
  1. Yes it is connected right to COM13
  2. \.\COM13 writing this solved the problem
MANY MNY THANKS… :slight_smile:
