GD32 continuous programming mode
Hi All!
If anybody have experience with Giga Device. I’m using GD32 programmer to program 12 boards together with option (Continuous programming mode) but facing some issue’s it programmer some of the board’s only like board 3, 6 and 8 doesn’t program. The issue I think is I’m using arduino program and relay for switching. In relay connections i put CLK (from programmer) pin as on com and normally open is board CLK pin and remaining pins are separately common with all boards and programmer pins VCC, RESET, INPUT and GND.
I have check everything but not able to find the reason why it’s happening to me i think the using CLK as common is causing issue but could’t find any other way
Let me know if any one worked on it before
Thanks
