Hey Community,
I have a problem while uploading fuses to a custom board with a atmgega 324pb. With Atmel Studio uploading works without problems.
I tried to upload the fuses via Platformio-> Platform-> Set Fuses
i have the following .ini file
[env:ATmega324PB]
board = ATmega324PB
board_build.f_cpu = 8000000L
board_fuse.lfuse = 0xD2
board_fuse.hfuse = 0xD1
board_fuse.efuse = 0xF7
upload_protocol = custom
upload_port = usb
upload_flags =
-C
-p
$BOARD_MCU
-P
$UPLOAD_PORT
-c
avrispmkII
But got the following output in the Terminal while uploading
TARGET CONFIGURATION:
Target = atmega324pb
Clock speed = 8000000L
Oscillator = external
BOD level = 2.7v
Save EEPROM = yes
UART port = uart0
Clock output = no
JTAG enable = no
CFD enable = no
Warning: The `custom` upload protocol is used! The upload and fuse flags may conflict!
More information: https://docs.platformio.org/en/latest/platforms/atmelavr.html#overriding-default-fuses-command
Selected fuses: [lfuse = 0xff, hfuse = 0xd6, efuse = 0xf5]
Setting fuses
These Fuse are different from the fuseses in the .ini file and “destroyed” my µC. How can i prevent to upload the wrong fuses
