I am using VSCODE with plug-in PlatformIO on Windows 10 to code for ESP8266.
I am modifying a project downloaded from GitHub, which has a rather big main cpp file with many functions.
In other development IDE systems I have used there is always a way to enable a panel, which shows the existing functions in the visible source file and by clicking in that list one can jump easily to the wanted function.
But I cannot for the life of me find where I can enable such a window in PlatformIO…
In text editor Notepad-pp it is very simple but I do not want to use that as my programming editor.
Here is how it looks like in notepad-pp:
How can I enable a similar panel in PlatformIO to navigate quickly inside the source?
Furthermore, through the command pallete, if you press Ctrl+P, you get a quick navigation:
So I can type Ctrl+P, @setup, Enter, and be in my function. Or I can type a filename, press enter, and be in that file.
Same for “Goto symbol in file: Ctrl+Shift+O”, then you don’t need to type the @:
All of that is documented in
A last addendum, PlatformIO integrates nicely with the VSCode command pallete (Ctrl+Shift+P) by providing the PlatformIO related tasks for build, clean, upload, etc, quickly reachable.
Thanks, this is almost what I want…
But the list contains not only the functions but also a lot of defines of variables and constants, which makes the list unwieldy.
Can I somehow limit the outline scope to only show functions?
