I’m not able to build my project when using the deep+ ldf_mode and #include <SD_MMC.h>
I get the following error :
In file included from C:/Users/mgarnier/.platformio/packages/framework-arduinoespressif32/libraries/SD_MMC/src/SD_MMC.cpp:16:
C:/Users/mgarnier/.platformio/packages/framework-arduinoespressif32/libraries/SD_MMC/src/SD_MMC.h:21:10: fatal error: FS.h: No such file or directory
I’m using the last up to date version of platformio, arduino framework and board esp32dev
You can reproduce the error by creating a new project, setting the ldf mode to deep+, and including SD_MMC.h.
main.cpp
#include <SD_MMC.h>
void setup()
void loop()
platformio.ini
[env:featheresp32]
board = featheresp32
lib_ldf_mode = chain+
It works normally when using chain or deep modes, but not with chain+ or deep+
I’m a bit lost with this error and I really need the deep+ mode
Any help is appreciated
Thanks !
You’re right indeed. With lib_ldf_mode = chain+ or deep+, the dependency of SD_MMC to the FS library is not detected and the build fails.
|-- SD_MMC @ 2.0.0
However, with no lib_ldf_mode set, or set to deep or chain, it succeeds.
|-- SD_MMC @ 2.0.0
| |-- FS @ 2.0.0
RAM: [ ] 4.9% (used 16144 bytes from 327680 bytes)
Flash: [== ] 16.2% (used 212977 bytes from 1310720 bytes)
So, although deep+ and chain+ should evaluate the #ifdef macros, in the SD_MMC.h file does
PlatformIO doesn’t seem to think that SOC_SDMMC_HOST_SUPPORTED is enabled, although it is set so in the soc/soc_caps.h file included previously.
I will open a bug report about this.
A workaround is adding
build_flags = -DSOC_SDMMC_HOST_SUPPORTED
to the platformio.ini, then deep+ mode can be used.
Nice !
Your workaround is working fine, thank you for your help !
I am reurrecting an old topic, because I am having the exact same issue when trying to work with TFT_eSPI (which, under the covers, includes FS.H). The difference: Adding the define for SOC_SDMMC_HIST_SUPPORTED does not circumvent the issue. Using the following PLATFORMIO,INI
[platformio]
description = Test SUNTON 3.5 TFT mit eSPI
-DUSER_SETUP_LOADED=1
-include $PROJECTDIR/Include/User_Setup.h
upload_speed = 460800
lib_ldf_mode = deep+
lib_deps = bodmer/TFT_eSPI @ ^2.5.23
will fail the compile with
Removing unused dependencies...
PLATFORM: Espressif 32 (6.1.0) > Espressif ESP32 Dev Module
- framework-arduinoespressif32 @ 3.20007.0 (2.0.7)
- tool-esptoolpy @ 1.40500.0 (4.5.0)
LDF Modes: Finder ~ deep+, Compatibility ~ soft
Found 47 compatible libraries
|-- TFT_eSPI @ 2.5.23
| |-- SPI @ 2.0.0
|-- SPI @ 2.0.0
Compiling .pio\build\esp32dev\src\main.cpp.o
Building .pio\build\esp32dev\bootloader.bin
Generating partitions .pio\build\esp32dev\partitions.bin
esptool.py v4.5
Creating esp32 image...
Merged 1 ELF section
Compiling .pio\build\esp32dev\lib9e3\SPI\SPI.cpp.o
In file included from .pio/libdeps/esp32dev/TFT_eSPI/TFT_eSPI.h:100,
from src/main.cpp:2:
.pio/libdeps/esp32dev/TFT_eSPI/Processors/TFT_eSPI_ESP32.h:137:12: fatal error: FS.h: No such file or directory
* Looking for FS.h dependency? Check our library registry!
* CLI > platformio lib search "header:FS.h"
* Web > https://registry.platformio.org/search?q=header:FS.h
#include <FS.h>
compilation terminated.
Compiling .pio\build\esp32dev\lib4b2\TFT_eSPI\TFT_eSPI.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\Esp.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\FirmwareMSC.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\FunctionalInterrupt.cpp.o
*** [.pio\build\esp32dev\src\main.cpp.o] Error 1
from .pio/libdeps/esp32dev/TFT_eSPI/TFT_eSPI.cpp:16:
#include <FS.h>
*** [.pio\build\esp32dev\lib4b2\TFT_eSPI\TFT_eSPI.cpp.o] Error 1
========================================================================================== [FAILED] Took 24.66 seconds ==========================================================================================
when I change to lib_ldf_mode = deep, compile succeeds.
Probaby error 25 (The error is 25 inches in front of the screen), but I dont’t know and what to fix
With best regards
Volker
