Unable to debug an ESP32-WROVER-E module over JTAG. After upload, the target is not halted at setup() and debug console displays the following when attempting to pause execution:
Breakpoint 1 at 0x40103330: file src/main.cpp, line 8.
PlatformIO: Resume the execution to `debug_init_break = break setup`
PlatformIO: More configuration options -> https://bit.ly/pio-debug
Note: automatically using hardware breakpoints for read-only addresses.
Info : [esp32.cpu0] Target halted, PC=0x400093C8, debug_reason=00000000
Info : Set GDB target to 'esp32.cpu0'
Info : [esp32.cpu1] Target halted, PC=0x400076E0, debug_reason=00000000
Error: FreeRTOS maximum used priority is unreasonably big, not proceeding: 127
Program
received signal SIGINT, Interrupt.
0x400093c8 in ?? ()
As for uxTopUsedPriority, in an STM32 project I had to add an explicit reference that is not optimized out for the debugger to work. You can tell gcc to generate a map file and make sure that this symbol has a non zero value.
Thanks for the suggestions!
Doesn’t look like I can use menuconfig (forgot to mention I’m using VSCode and Arduino framework), but borrowing the code snippet from your STM project has cleared up the RTOS error.
Unfortunately it still does not pause execution correctly, now it’s an endless stream of:
Error: Unexpected OCD_ID = 00000000
Info : [esp32.cpu0] Debug controller was reset.
Info : [esp32.cpu0] Core was reset.
Any thoughts? Feels like a totally new issue and so maybe deserves a separate topic/post.
