I am facing an issue where the framework-arduinoespressif32 V3.2 is supposed to be the one installed - but the files actually installed are an older version (2.x afaik? the file esp32-hal-ledc.c still has the deprecated ledcAttachPin method)
Here is the log from building where it suggest to use the older method (which is indeed the one in the current file).
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/upesy_wroom.html
PLATFORM: Espressif 32 (6.11.0) > uPesy ESP32 Wroom DevKit
- framework-arduinoespressif32 @ 3.20017.241212+sha.dcc1105b
Found 33 compatible libraries
Compiling .pio\build\upesy_wroom\src\main.cpp.o
src/main.cpp: In function 'void setup()':
src/main.cpp:34:3: error: 'ledcAttach' was not declared in this scope
ledcAttach(LED_PIN, LEDC_BASE_FREQ, LEDC_TIMER_12_BIT);
src/main.cpp:34:3: note: suggested alternative: 'ledcAttachPin'
Let me know if you need more information to pinpoint the issue!
