Found truncated file names under framework-mbed/features/FEATURE_BLE directories
I am trying to move from PlatformIO 4 to PlatformIO 6 with the codebase from mbedOS 5.13.x.
While the changeover on platformio.ini to specify using mbedOS 5.15.06 ended up not difficult, I found a very strange issue where some of the filenames under framework-mbed/features/FEATURE_BLE directories are truncated and with 1970-1-1 file date too.
williamto@NZLT2300093:~/PIO/framework-mbed/features/FEATURE_BLE/targets/TARGET_NORDIC/TARGET_NORDIC_CORDIO/TARGET_NRF5x$ ls -lrt
total 32
-rw-r--r-- 1 williamto williamto   774 Jan  1  1970 README.md
-rw-r--r-- 1 williamto williamto  1920 Jan  1  1970 NRFCordioHCITransportDr
-rw-r--r-- 1 williamto williamto  2492 Jan  1  1970 NRFCordioHCIDriver.h
-rw-r--r-- 1 williamto williamto 11963 Jan  1  1970 NRFCordioHCIDriver.cpp
-rw-r--r-- 1 williamto williamto   575 Jan  1  1970 mbed_lib.json
drwxrwxr-x 4 williamto williamto  4096 Jul  3 09:21 stack
williamto@NZLT2300093:~/PIO/framework-mbed/features/FEATURE_BLE/targets/TARGET_NORDIC/TARGET_NORDIC_CORDIO/TARGET_NRF5x/stack/sources$ ls -lrt
total 132
-rw-r--r-- 1 williamto williamto 10125 Jan  1  1970 pal_uart.
-rw-r--r-- 1 williamto williamto 13734 Jan  1  1970 pal_twi.c
-rw-r--r-- 1 williamto williamto  7897 Jan  1  1970 pal_timer
-rw-r--r-- 1 williamto williamto  7884 Jan  1  1970 pal_sys.c
-rw-r--r-- 1 williamto williamto  4641 Jan  1  1970 pal_rtc.c
-rw-r--r-- 1 williamto williamto 11768 Jan  1  1970 pal_nvm.c
-rw-r--r-- 1 williamto williamto  7755 Jan  1  1970 pal_led.c
-rw-r--r-- 1 williamto williamto 27758 Jan  1  1970 pal_crypt
-rw-r--r-- 1 williamto williamto 10870 Jan  1  1970 pal_cfg.c
-rw-r--r-- 1 williamto williamto  7625 Jan  1  1970 pal_bb.c
-rw-r--r-- 1 williamto williamto  8566 Jan  1  1970 pal_bb_bl
The build will fail because the build system will consider the truncated files as “missing”.
I used git to check out the source code from GitHub - ARMmbed/mbed-os at mbed-os-5.15.6 and it seems there is no issue similar to the “filename of death”.
The PlatformIO development system is run on Ubuntu 22 directly on metal and not on WSL.
You’re right, the package is indeed faulty:
https://dl.registry.platformio.org/download/platformio/tool/framework-mbed/6.51506.230421/framework-mbed-6.51506.230421.tar.gz
So, that’s something for the PlatformIO people to fix. Can you file an issue in Issues · platformio/platform-nordicnrf52 · GitHub?
I think you can work-around it if you get a clean copy of mbedos 5.15.06 and then re-add the package.json file and platformio folder from the above PlatformIO package. You could then reference this clean / fixed package with a platform_packages like
platform_packages =
   framework-mbed@symlink:///home/user/mbedos_fixed
to reference /home/user/mbedos_fixed.
