I had discovered that this library GitHub - khoih-prog/ESP_WiFiManager: This is an ESP32 / ESP8266 WiFi Connection Manager with fallback web configuration portal. Use this library for configuring ESP32, ESP8266 modules' WiFi, etc. Credentials at runtime. You can also specify static DNS servers, personalized HostName, fixed or random AP WiFi channel. With examples supporting ArduinoJson 6.0.0+ as well as 5.13.5- . was spitted in 2 libraries on library manager:
- A professional collaborative platform for embedded development · PlatformIO stop at 1.3.0
- A professional collaborative platform for embedded development · PlatformIO which is the most updated
The weird thing is that the version 1.3.0 and 1.2.0 appear in both forks. Is it possibile to fix this “split”?
