I’m having trouble building a project:
Processing emontx (platform: atmelavr; framework: arduino; board: uno)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/uno.html
PLATFORM: Atmel AVR (3.1.0) > Arduino Uno
- framework-arduino-avr 5.1.0
Converting src.ino
ValueError: Invalid simple block 'c057b5f4c0':
File "/usr/local/lib/python2.7/dist-packages/platformio/builder/main.py", line 170:
File "/home/glyn/.platformio/packages/tool-scons/script/../engine/SCons/Script/SConscript.py", line 541:
File "/home/glyn/.platformio/packages/tool-scons/script/../engine/SCons/Script/SConscript.py", line 250:
exec _file_ in call_stack[-1].globals
File "/home/glyn/.platformio/platforms/atmelavr/builder/main.py", line 162:
File "/home/glyn/.platformio/packages/tool-scons/script/../engine/SCons/Environment.py", line 224:
File "/usr/local/lib/python2.7/dist-packages/platformio/builder/tools/platformio.py", line 62:
env.ProcessProjectDeps()
File "/usr/local/lib/python2.7/dist-packages/platformio/builder/tools/platformio.py", line 140:
project_lib_builder = env.ConfigureProjectLibBuilder()
File "/usr/local/lib/python2.7/dist-packages/platformio/builder/tools/piolib.py", line 1062:
project.install_dependencies()
File "/usr/local/lib/python2.7/dist-packages/platformio/builder/tools/piolib.py", line 886:
if lm.get_package(spec):
File "/usr/local/lib/python2.7/dist-packages/platformio/package/manager/base.py", line 234:
spec = self.ensure_spec(spec)
File "/usr/local/lib/python2.7/dist-packages/platformio/package/manager/base.py", line 102:
return spec if isinstance(spec, PackageSpec) else PackageSpec(spec)
File "/usr/local/lib/python2.7/dist-packages/platformio/package/meta.py", line 119:
self._parse(raw)
File "/usr/local/lib/python2.7/dist-packages/platformio/package/meta.py", line 222:
raw = parser(raw)
File "/usr/local/lib/python2.7/dist-packages/platformio/package/meta.py", line 245:
self.requirements = tokens[1].strip()
File "/usr/local/lib/python2.7/dist-packages/platformio/package/meta.py", line 162:
else semantic_version.SimpleSpec(str(value))
File "/usr/local/lib/python2.7/dist-packages/semantic_version/base.py", line 618:
self.clause = self._parse_to_clause(expression)
File "/usr/local/lib/python2.7/dist-packages/semantic_version/base.py", line 1014:
return cls.Parser.parse(expression)
File "/usr/local/lib/python2.7/dist-packages/semantic_version/base.py", line 1034:
raise ValueError("Invalid simple block %r" % block)
I think the issue is due to Platformio still using python 2
PlatformIO Core Executable /usr/local/bin/platformio
File System Encoding UTF-8
Locale Encoding UTF-8
PlatformIO Core 5.0.4
System Type linux_x86_64
PlatformIO Core Directory /home/glyn/.platformio
Python Executable /usr/bin/python
Platform Linux-4.15.0-128-generic-x86_64-with-glibc2.15
Tools & Toolchains 5
Global Libraries 0
Development Platforms 1
Python 2.7.17-final.0
I have python3 installed:
python3 --version
Python 3.6.9
I have followed the instructions: Migrating from 5.x to 6.0 — PlatformIO latest documentation
to remove the folder USER_HOME_DIR/.platformio/penv
the reinstall pio using the install script, this didn’t seem to make any differance pio is still using python 2.7.17.
How can I force pio to use python3?
