Floating Point Exception(core dumped)
I’m trying to upload firmware to Odroid XU4, SmartPower 2.
I made a change to increase logging frequency of power consumption data.
The code for firmware was taken from here: GitHub - hardkernel/smartpower2
These two commands run fine(with some warnings about some enumeration value and unused variables):
sudo platformio run
sudo platformio run --target upload
when I run the following command, I’m getting the shown error:
sudo platformio run --target uploadfs
Processing esp12e (platform: espressif8266; board: esp12e; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/esp12e.html
PLATFORM: Espressif 8266 > Espressif ESP8266 ESP-12E
HARDWARE: ESP8266 160MHz 80KB RAM (4MB Flash)
Converting smartpower2.ino
Collected 30 compatible libraries
|-- <WebSockets> 2.1.3
|   |-- <Hash> 1.0
|   |-- <ESP8266WiFi> 1.0
|   |-- <SPI> 1.0
|   |-- <Ethernet(esp8266)> 1.0.4
|   |   |-- <SPI> 1.0
|-- <LiquidCrystal_I2C>
|   |-- <Wire> 1.0
|-- <mcp4652>
|   |-- <Wire> 1.0
|-- <Hash> 1.0
|-- <SimpleTimer>
|-- <ESP8266WebServer> 1.0
|-- <Wire> 1.0
Building SPIFFS image from 'data' directory to .pioenvs/esp12e/spiffs.bin
Floating point exception (core dumped)
*** [.pioenvs/esp12e/spiffs.bin] Error 136
====================================================================== [ERROR] Took 0.76 seconds ======================================================================
Can someone help me out with this? There’s another issue like this but that issue doesn’t really address the problem plus the error code is different.
Thanks
