Hi, I am trying out platfirmIO (after using Arduino for a number of years) for the first time. I also have bought a DFRobot Firebeetle32 board (rather than the unnamed dev boards) and I am having trouble compiling even the most basic project.
I installed platformio extension into VSCode. That seemed to work fine, and I created a new project and specified the firebeetle32 as it was in the list of boards. it seemed to download support ok.
My platform.ini contains
[env:firebeetle32]
board = firebeetle32
Code is
Errors are below. I understand what the errors are, but not how to get around them as I only include Arduino.h
In file included from C:\Users\Stephen.platformio\packages\framework-arduinoespressif32\cores\esp32\HardwareSerial.cpp:20:0:
C:\Users\Stephen.platformio\packages\framework-arduinoespressif32\variants\firebeetle32/pins_arduino.h:62:22: error: redefinition of ‘const uint8_t D0’
static const uint8_t D0 = 3;
C:\Users\Stephen.platformio\packages\framework-arduinoespressif32\variants\firebeetle32/pins_arduino.h:33:22: note: ‘const uint8_t D0’ previously defined here
C:\Users\Stephen.platformio\packages\framework-arduinoespressif32\variants\firebeetle32/pins_arduino.h:63:22: error: redefinition of ‘const uint8_t D1’
static const uint8_t D1 = 1;
C:\Users\Stephen.platformio\packages\framework-arduinoespressif32\variants\firebeetle32/pins_arduino.h:34:22: note: ‘const uint8_t D1’ previously defined here
Any ideas?
