Hi, I was trying to use firebase in my latest project. When I add the Firebase_ESP_Client library to my project and use it in a .cpp file it works fine. However, when I try making the FirebaseData object a global variable by placing it in a header file, I run into multiple problems:
Here are the output errors:
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/rtdb/QueryFilter.h:74:35: error: expected initializer before 'enable_if'
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/rtdb/QueryFilter.h:77:37: error: expected nested-name-specifier before 'enable_if'
auto equalTo(T val) -> typename enable_if<is_num_int<T>::value, QueryFilter &>::type { return mEqualTo(toStringPtr(val), false); }
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/rtdb/QueryFilter.h:77:37: error: expected initializer before 'enable_if'
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/rtdb/QueryFilter.h:80:37: error: expected nested-name-specifier before 'enable_if'
auto equalTo(T val) -> typename enable_if<is_string<T>::value, QueryFilter &>::type { return mEqualTo(toStringPtr(val), true); }
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/rtdb/QueryFilter.h:80:37: error: expected initializer before 'enable_if'
In file included from .pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/Firebase.h:65,
from .pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/Firebase_ESP_Client.h:42,
from src/firebase.h:4,
from src/main.cpp:25:
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/session/FB_Session.h:615:25: error: expected nested-name-specifier before 'enable_if'
auto to() -> typename enable_if<is_num_int<T>::value || is_num_float<T>::value || is_bool<T>::value, T>::type
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/session/FB_Session.h:615:25: error: expected initializer before 'enable_if'
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/session/FB_Session.h:668:25: error: expected nested-name-specifier before 'enable_if'
auto to() -> typename enable_if<is_const_chars<T>::value || is_std_string<T>::value || is_arduino_string<T>::value || is_mb_string<T>::value, T>::type
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/session/FB_Session.h:668:25: error: expected initializer before 'enable_if'
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/session/FB_Session.h:676:25: error: expected nested-name-specifier before 'enable_if'
auto to() -> typename enable_if<is_same<T, FirebaseJson *>::value, FirebaseJson *>::type
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/session/FB_Session.h:676:25: error: expected initializer before 'enable_if'
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/session/FB_Session.h:692:25: error: expected nested-name-specifier before 'enable_if'
auto to() -> typename enable_if<is_same<T, FirebaseJsonData *>::value, FirebaseJsonData *>::type
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/session/FB_Session.h:692:25: error: expected initializer before 'enable_if'
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/session/FB_Session.h:700:25: error: expected nested-name-specifier before 'enable_if'
auto to() -> typename enable_if<is_same<T, FirebaseJson>::value, FirebaseJson &>::type
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/session/FB_Session.h:700:25: error: expected initializer before 'enable_if'
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/session/FB_Session.h:706:25: error: expected nested-name-specifier before 'enable_if'
auto to() -> typename enable_if<is_same<T, FirebaseJsonArray *>::value, FirebaseJsonArray *>::type
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/session/FB_Session.h:706:25: error: expected initializer before 'enable_if'
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/session/FB_Session.h:723:25: error: expected nested-name-specifier before 'enable_if'
auto to() -> typename enable_if<is_same<T, FirebaseJsonArray>::value, FirebaseJsonArray &>::type
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/session/FB_Session.h:723:25: error: expected initializer before 'enable_if'
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/session/FB_Session.h:729:25: error: expected nested-name-specifier before 'enable_if'
auto to() -> typename enable_if<is_same<T, MB_VECTOR<uint8_t> *>::value, MB_VECTOR<uint8_t> *>::type
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/session/FB_Session.h:729:25: error: expected initializer before 'enable_if'
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/session/FB_Session.h:736:25: error: expected nested-name-specifier before 'enable_if'
auto to() -> typename enable_if<is_same<T, fs::File>::value, fs::File>::type
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/session/FB_Session.h:736:25: error: expected initializer before 'enable_if'
In file included from .pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/Firebase.h:74,
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/rtdb/FB_RTDB.h:1888:106: error: expected nested-name-specifier before 'enable_if'
auto dataPushHandler(FirebaseData *fbdo, T1 path, T2 value, int priority_addr, bool async) -> typename enable_if<is_string<T1>::value && is_num_int<T2>::value, bool>::type
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/rtdb/FB_RTDB.h:1888:106: error: expected initializer before 'enable_if'
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/rtdb/FB_RTDB.h:1894:106: error: expected nested-name-specifier before 'enable_if'
auto dataPushHandler(FirebaseData *fbdo, T1 path, T2 value, int priority_addr, bool async) -> typename enable_if<is_string<T1>::value && is_bool<T2>::value, bool>::type
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/rtdb/FB_RTDB.h:1894:106: error: expected initializer before 'enable_if'
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/rtdb/FB_RTDB.h:1900:106: error: expected nested-name-specifier before 'enable_if'
auto dataPushHandler(FirebaseData *fbdo, T1 path, T2 value, int priority_addr, bool async) -> typename enable_if<is_string<T1>::value && is_same<T2, float>::value, bool>::type
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/rtdb/FB_RTDB.h:1900:106: error: expected initializer before 'enable_if'
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/rtdb/FB_RTDB.h:1906:106: error: expected nested-name-specifier before 'enable_if'
auto dataPushHandler(FirebaseData *fbdo, T1 path, T2 value, int priority_addr, bool async) -> typename enable_if<is_string<T1>::value && is_same<T2, double>::value, bool>::type
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/rtdb/FB_RTDB.h:1906:106: error: expected initializer before 'enable_if'
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/rtdb/FB_RTDB.h:1912:106: error: expected nested-name-specifier before 'enable_if'
auto dataPushHandler(FirebaseData *fbdo, T1 path, T2 value, int priority_addr, bool async) -> typename enable_if<is_string<T1>::value && is_string<T2>::value, bool>::type
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/rtdb/FB_RTDB.h:1912:106: error: expected initializer before 'enable_if'
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/rtdb/FB_RTDB.h:1918:105: error: expected nested-name-specifier before 'enable_if'
auto dataPushHandler(FirebaseData *fbdo, T1 path, T2 json, int priority_addr, bool async) -> typename enable_if<is_string<T1>::value && is_same<T2, FirebaseJson *>::value, bool>::type
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/rtdb/FB_RTDB.h:1918:105: error: expected initializer before 'enable_if'
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/rtdb/FB_RTDB.h:1924:104: error: expected nested-name-specifier before 'enable_if'
auto dataPushHandler(FirebaseData *fbdo, T1 path, T2 arr, int priority_addr, bool async) -> typename enable_if<is_string<T1>::value && is_same<T2, FirebaseJsonArray *>::value, bool>::type
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/rtdb/FB_RTDB.h:1924:104: error: expected initializer before 'enable_if'
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/rtdb/FB_RTDB.h:1930:99: error: expected nested-name-specifier before 'enable_if'
auto dataPushHandler(FirebaseData *fbdo, T1 path, T2 blob, size_t size, bool async) -> typename enable_if<is_string<T1>::value && is_same<T2, uint8_t *>::value, bool>::type
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/rtdb/FB_RTDB.h:1930:99: error: expected initializer before 'enable_if'
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/rtdb/FB_RTDB.h:1936:127: error: expected nested-name-specifier before 'enable_if'
auto dataPushHandler(FirebaseData *fbdo, T1 path, T2 filename, fb_esp_mem_storage_type storageType, bool async) -> typename enable_if<is_string<T1>::value && is_string<T2>::value, bool>::type
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/rtdb/FB_RTDB.h:1936:127: error: expected initializer before 'enable_if'
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/rtdb/FB_RTDB.h:1942:114: error: expected nested-name-specifier before 'enable_if'
auto dataSetHandler(FirebaseData *fbdo, T1 path, T2 value, int priority_addr, T3 etag, bool async) -> typename enable_if<is_string<T1>::value && is_bool<T2>::value, bool>::type
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/rtdb/FB_RTDB.h:1942:114: error: expected initializer before 'enable_if'
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/rtdb/FB_RTDB.h:1948:114: error: expected nested-name-specifier before 'enable_if'
auto dataSetHandler(FirebaseData *fbdo, T1 path, T2 value, int priority_addr, T3 etag, bool async) -> typename enable_if<is_string<T1>::value && is_num_int<T2>::value, bool>::type
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/rtdb/FB_RTDB.h:1948:114: error: expected initializer before 'enable_if'
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/rtdb/FB_RTDB.h:1954:114: error: expected nested-name-specifier before 'enable_if'
auto dataSetHandler(FirebaseData *fbdo, T1 path, T2 value, int priority_addr, T3 etag, bool async) -> typename enable_if<is_string<T1>::value && is_same<T2, float>::value, bool>::type
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/rtdb/FB_RTDB.h:1954:114: error: expected initializer before 'enable_if'
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/rtdb/FB_RTDB.h:1960:114: error: expected nested-name-specifier before 'enable_if'
auto dataSetHandler(FirebaseData *fbdo, T1 path, T2 value, int priority_addr, T3 etag, bool async) -> typename enable_if<is_string<T1>::value && is_same<T2, double>::value, bool>::type
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/rtdb/FB_RTDB.h:1960:114: error: expected initializer before 'enable_if'
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/rtdb/FB_RTDB.h:1966:114: error: expected nested-name-specifier before 'enable_if'
auto dataSetHandler(FirebaseData *fbdo, T1 path, T2 value, int priority_addr, T3 etag, bool async) -> typename enable_if<is_string<T1>::value && is_string<T2>::value, bool>::type
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/rtdb/FB_RTDB.h:1966:114: error: expected initializer before 'enable_if'
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/rtdb/FB_RTDB.h:1972:113: error: expected nested-name-specifier before 'enable_if'
auto dataSetHandler(FirebaseData *fbdo, T1 path, T2 json, int priority_addr, T3 etag, bool async) -> typename enable_if<is_string<T1>::value && is_same<T2, FirebaseJson *>::value, bool>::type
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/rtdb/FB_RTDB.h:1972:113: error: expected initializer before 'enable_if'
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/rtdb/FB_RTDB.h:1978:112: error: expected nested-name-specifier before 'enable_if'
auto dataSetHandler(FirebaseData *fbdo, T1 path, T2 arr, int priority_addr, T3 etag, bool async) -> typename enable_if<is_string<T1>::value && is_same<T2, FirebaseJsonArray *>::value, bool>::type
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/rtdb/FB_RTDB.h:1978:112: error: expected initializer before 'enable_if'
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/rtdb/FB_RTDB.h:1984:113: error: expected nested-name-specifier before 'enable_if'
auto dataSetHandler(FirebaseData *fbdo, T1 path, uint8_t *blob, size_t size, T2 etag, bool async) -> typename enable_if<is_string<T1>::value, bool>::type
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/rtdb/FB_RTDB.h:1984:113: error: expected initializer before 'enable_if'
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/rtdb/FB_RTDB.h:1990:135: error: expected nested-name-specifier before 'enable_if'
auto dataSetHandler(FirebaseData *fbdo, T1 path, T2 filename, fb_esp_mem_storage_type storageType, T3 etag, bool async) -> typename enable_if<is_string<T1>::value && is_string<T2>::value, bool>::type
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/rtdb/FB_RTDB.h:1990:135: error: expected initializer before 'enable_if'
In file included from .pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/./mbfs/MB_FS_Interfaces.h:90,
from .pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/./mbfs/MB_FS.h:37,
from .pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/FB_Const.h:45,
from .pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/FB_Utils.h:37,
from .pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/Firebase.h:62,
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/json/FirebaseJson.h: In instantiation of 'bool FirebaseJson::setJsonData(T) [with T = const char*]':
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/FB_Utils.h:657:35: required from here
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/json/FirebaseJson.h:2357:33: error: 'getStr' was not declared in this scope
bool ret = setRaw(getStr(data, addr));
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/json/FirebaseJson.h:2357:33: note: suggested alternative: 'get'
get
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/json/FirebaseJson.h: In instantiation of 'bool FirebaseJson::get(FirebaseJsonData&, T, bool) [with T = const char*]':
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/FB_Utils.h:658:54: required from here
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/json/FirebaseJson.h:2502:46: error: 'getStr' was not declared in this scope
bool ret = mGet(root, &result, getStr(path, addr), prettify);
.pio/libdeps/esp32dev/Firebase Arduino Client Library for ESP8266 and ESP32/src/json/FirebaseJson.h:2502:46: note: suggested alternative: 'get'
get
*** [.pio\build\esp32dev\src\main.o] Error 1
Here’s my header file (firebase.h):
#ifndef firebase_H_
#define firebase_H_
#include <string.h>
#include <Firebase_ESP_Client.h>
void firebaseSetup();
void firebaseLoopSend();
void firebaseLoopRead();
void firebaseWriteData(String topic, void* value, char* datatype);
//Define Firebase Data object
extern FirebaseData fbdo;
extern FirebaseAuth auth;
extern FirebaseConfig config;
Here is my firebase.cpp file:
#if defined(ESP32)
#include <WiFi.h>
#elif defined(ESP8266)
#include <ESP8266WiFi.h>
#include "firebase.h"
//Provide the token generation process info.
#include "addons/TokenHelper.h"
//Provide the RTDB payload printing info and other helper functions.
#include "addons/RTDBHelper.h"
// Insert your network credentials
#define WIFI_SSID "SSID_HERE"
#define WIFI_PASSWORD "PW_HERE"
// Insert Firebase project API Key
#define API_KEY "API_KEY_HERE"
// Insert RTDB URLefine the RTDB URL */
#define DATABASE_URL "URL_HERE"
FirebaseData fbdo;
FirebaseAuth auth;
unsigned long sendDataPrevMillis = 0;
int count = 0;
bool signupOK = false;
int intValue;
float floatValue;
void firebaseSetup(){
//Serial.begin(115200);
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
Serial.print("Connecting to Wi-Fi");
while (WiFi.status() != WL_CONNECTED){
Serial.print(".");
delay(300);
Serial.println();
Serial.print("Connected with IP: ");
Serial.println();
/* Assign the api key (required) */
config.api_key = API_KEY;
/* Assign the RTDB URL (required) */
config.database_url = DATABASE_URL;
/* Sign up */
if (Firebase.signUp(&config, &auth, "", "")){
Serial.println("ok");
signupOK = true;
else{
Serial.printf("%s\n", config.signer.signupError.message.c_str());
/* Assign the callback function for the long running token generation task */
config.token_status_callback = tokenStatusCallback; //see addons/TokenHelper.h
Firebase.begin(&config, &auth);
Firebase.reconnectWiFi(true);
//firebaseLoopSend();
disableCore0WDT();
disableCore1WDT();
firebaseWriteData("Test2/String", (void*)"Matthew got this working", "String");
firebaseLoopRead();
void firebaseLoopSend(){
while (true){
if (Firebase.ready() && signupOK && (millis() - sendDataPrevMillis > 15000 || sendDataPrevMillis == 0)){
sendDataPrevMillis = millis();
// Write an Int number on the database path test/int
if (Firebase.RTDB.setInt(&fbdo, "test/int", count)){
Serial.println("PASSED");
Serial.println("PATH: " + fbdo.dataPath());
Serial.println("TYPE: " + fbdo.dataType());
else {
Serial.println("FAILED");
Serial.println("REASON: " + fbdo.errorReason());
count++;
// Write an Float number on the database path test/float
if (Firebase.RTDB.setFloat(&fbdo, "test/float", 0.01 + random(0,100))){
else {
while(true){
if (Firebase.ready() && signupOK && (millis() - sendDataPrevMillis > 15000 || sendDataPrevMillis == 0)) {
if (Firebase.RTDB.getInt(&fbdo, "/test/int")) {
if (fbdo.dataType() == "int") {
intValue = fbdo.intData();
Serial.println(intValue);
else {
Serial.println(fbdo.errorReason());
if (Firebase.RTDB.getFloat(&fbdo, "/test/float")) {
if (fbdo.dataType() == "float") {
floatValue = fbdo.floatData();
Serial.println(floatValue);
else {
if (Firebase.ready() && signupOK)
if (strcmp(datatype, "String") == 0)
Firebase.RTDB.setString(&fbdo, topic, (char*)value);
Just to reiterate, if I remove the line #include <Firebase_ESP_Client.h>
from my header file, I don’t get these errors. However, I need this line to make the FirebaseData fbdo
object global (so that I can read and write data to the database from other files). How can I get around this issue?
