I created an example project to demonstrate this problem (likely a misunderstanding on my part). It seems that if I add libraries in my project’s lib/
folder that they compile, but the linker can’t find functions within them. Hopefully someone can slap some knowledge on me.
$ tree
├── include
│ └── README
├── lib
│ ├── README
│ └── foo
│ └── src
│ ├── foo.c
│ └── foo.h
├── platformio.ini
├── src
│ └── main.cpp
└── test
└── README
6 directories, 7 files
$ cat lib/foo/src/foo.h lib/foo/src/foo.c src/main.cpp
--- foo.h
void fooCall();
--- foo.c
void fooCall() {
int x = 0;
--- main.cpp
#include "Arduino.h"
#include <foo.h>
void setup()
void loop()
fooCall();
$ pio run
Processing nodemcuv2 (platform: espressif8266; board: nodemcuv2; framework: arduino)
---------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/nodemcuv2.html
PLATFORM: Espressif 8266 2.2.3 > NodeMCU 1.0 (ESP-12E Module)
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
PACKAGES: toolchain-xtensa 2.40802.190218 (4.8.2), tool-esptool 1.413.0 (4.13), tool-esptoolpy 1.20600.0 (2.6.0), framework-arduinoespressif8266 2.20502.0 (2.5.2)
Found 32 compatible libraries
|-- <foo>
Linking .pio/build/nodemcuv2/firmware.elf
/Users/nebulous/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld: .pio/build/nodemcuv2/src/main.cpp.o:(.text.loop+0x0): undefined reference to `fooCall()'
/Users/nebulous/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld: .pio/build/nodemcuv2/src/main.cpp.o: in function `loop':
main.cpp:(.text.loop+0xa): undefined reference to `fooCall()'
*** [.pio/build/nodemcuv2/firmware.elf] Error 1
======================================================== [FAILED] Took 1.48 seconds ========================================================
