I have a D1 Mini clone with 4mb of flash.
My platformio.ini file has these options:
[env:esp12e]
platform = espressif8266
board = esp12e
I have a 1.5mb hex file in my project’s /data directory. When running Build Filesystem Image, I’m getting an error: File system is full.
How do you build and upload more than 1mb of data to the ESP’s flash storage?
* Executing task: platformio run --target buildfs --environment esp12e
Processing esp12e (platform: espressif8266; board: esp12e; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/esp12e.html
PLATFORM: Espressif 8266 (3.2.0) > Espressif ESP8266 ESP-12E
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
- framework-arduinoespressif8266 @ 3.30002.0 (3.0.2)
- tool-esptool @ 1.413.0 (4.13)
- tool-esptoolpy @ 1.30000.201119 (3.0.0)
- tool-mkspiffs @ 1.200.0 (2.0)
- toolchain-xtensa @ 2.100300.210717 (10.3.0)
Found 35 compatible libraries
|-- LittleFS @ 0.1.0
|-- EspSoftwareSerial @ 6.12.7
Building file system image from 'data' directory to .pio/build/esp12e/littlefs.bin
/codes.hex
lfs warn:475: No more free space 158
lfs_write error(-28): File system is full.
error adding file!
*** [.pio/build/esp12e/littlefs.bin] Error 1
================================================================================ [FAILED] Took 0.73 seconds ================================================================================
Environment Status Duration
esp12e FAILED 00:00:00.730
=========================================================================== 1 failed, 0 succeeded in 00:00:00.730 ===========================================================================
