Hello! I am writing a simple file-serving http server using this example “esp-idf/examples/protocols/http_server/file_serving/main at f65c8249af109de349650b9cf79ae28399261750 · espressif/esp-idf · GitHub”, but I encountered a problem. I can’t build my program, nor build filesystem image, due to errors with /data directory, when I am trying to embed files to SPIFFS partition.
This is how my project structure looks like:
Rest of the project (I think) is configured in accordance to ESP-IDF documentation. Here are the most important parts:
partitions.csv ( partition configured in menu config as custom as well)
# Name, Type, SubType, Offset, Size, Flags
# Note: if you have increased the bootloader size, make sure to update the offsets to avoid overlap
nvs, data, nvs, 0x9000, 0x6000,
phy_init, data, phy, 0xf000, 0x1000,
factory, app, factory, 0x10000, 1M,
storage, data, spiffs, , 0xF0000,
platformio.ini
[env:nodemcu-32s]
board = nodemcu-32s
framework = espidf
board_build.partitions = partitions.csv
board_build.embed_txtfiles =
data/favicon.ico
data/upload_script.html
project CMakeList
cmake_minimum_required(VERSION 3.16.0)
include($ENV{IDF_PATH}/tools/cmake/project.cmake)
project(HTTP-server)
target_add_binary_data(HTTP-server.elf "data/favicon.ico" TEXT)
target_add_binary_data(HTTP-server.elf "data/upload_script.html" TEXT)
/src/CMakeList
FILE(GLOB_RECURSE app_sources ${CMAKE_SOURCE_DIR}/src/*.*)
idf_component_register(SRCS ${app_sources})
During compilation I get errors on those lines in file_system.c:
extern const unsigned char favicon_ico_start[] asm("_binary_favicon_ico_start");
extern const unsigned char favicon_ico_end[] asm("_binary_favicon_ico_end");
extern const unsigned char upload_script_start[] asm("_binary_upload_script_html_start");
extern const unsigned char upload_script_end[] asm("_binary_upload_script_html_end");
Linking .pio/build/nodemcu-32s/firmware.elf
/home/artur/.platformio/packages/toolchain-xtensa32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: .pio/build/nodemcu-32s/src/file_server.o:(.literal.http_resp_dir_html+0x14): undefined reference to `_binary_upload_script_html_end'
/home/artur/.platformio/packages/toolchain-xtensa32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: .pio/build/nodemcu-32s/src/file_server.o:(.literal.http_resp_dir_html+0x18): undefined reference to `_binary_upload_script_html_start'
/home/artur/.platformio/packages/toolchain-xtensa32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: .pio/build/nodemcu-32s/src/file_server.o:(.literal.favicon_get_handler+0x0): undefined reference to `_binary_favicon_ico_end'
/home/artur/.platformio/packages/toolchain-xtensa32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: .pio/build/nodemcu-32s/src/file_server.o:(.literal.favicon_get_handler+0x4): undefined reference to `_binary_favicon_ico_start'
*** [.pio/build/nodemcu-32s/firmware.elf] Error 1
================================================================================= [FAILED] Took 65.20 seconds =================================================================================
(on the other note, why is platformio always compiling all the files? it makes it so slow! why can’t it only compile those that were changed?)
And during “Build Filesystem Image” task I get this error:
*** [.pio/build/nodemcu-32s/spiffs.bin] Implicit dependency `data/favicon' not found, needed by target `.pio/build/nodemcu-32s/spiffs.bin'.
================================================================================= [FAILED] Took 5.70 seconds =================================================================================
The terminal process "platformio 'run', '--target', 'buildfs', '--environment', 'nodemcu-32s'" terminated with exit code: 1.
I would be very thankful for any advice.
