Fatal error: WatchDog.h: No such file or directory
I have added watchdog.h from libraries.
This is how platformio.ini looks :
[env:ATmega328P]
board = ATmega328P
nadavmatalon/WatchDog@^1.2.0
It is showing error like this
Please help. Thanks.
I think the library.json is poorly written becauase there is no framework called “AVR”. It’s framework = arduino. The platform is atmelavr. So AVR is any case just wrong.
You might be able to convince the LDF to include the library if you disable its sanity checks per docs:
lib_compat_mode = off
in the platformio.ini.
