For some reason I cannot use any libraries from std namespace, I try to include vector and it does not compile.
main.cpp:
#include <vector>
platformio.ini:
;PlatformIO Project Configuration File
[env:megaatmega2560]
board = megaatmega2560
after compiling:
> Executing task in folder testplatformio: platformio run <
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/megaatmega2560.html
PLATFORM: Atmel AVR > Arduino Mega or Mega 2560 ATmega2560 (Mega 2560)
HARDWARE: ATMEGA2560 16MHz 8KB RAM (248KB Flash)
Collected 5 compatible libraries
Compiling .pioenvs/megaatmega2560/src/main.cpp.o
src/main.cpp:2:18: fatal error: vector: No such file or directory
compilation terminated.
Compiling .pioenvs/megaatmega2560/FrameworkArduino/WMath.cpp.o
Compiling .pioenvs/megaatmega2560/FrameworkArduino/WString.cpp.o
Compiling .pioenvs/megaatmega2560/FrameworkArduino/abi.cpp.o
Compiling .pioenvs/megaatmega2560/FrameworkArduino/hooks.c.o
Compiling .pioenvs/megaatmega2560/FrameworkArduino/main.cpp.o
Compiling .pioenvs/megaatmega2560/FrameworkArduino/new.cpp.o
*** [.pioenvs/megaatmega2560/src/main.cpp.o] Error 1
Compiling .pioenvs/megaatmega2560/FrameworkArduino/wiring.c.o
============================================================================= [ERROR] Took 0.36 seconds =============================================================================
