Fatal error: TFT_eSPI.h: No such file or directory
Simple project. TFT_eSPI + LVGL.
I get the error:
Compiling .pio\build\esp32\lib969\lvgl\drivers\evdev\lv_evdev.c.o
Compiling .pio\build\esp32\lib969\lvgl\drivers\glfw\lv_glfw_window.c.o
.pio/libdeps/esp32/lvgl/src/drivers/display/tft_espi/lv_tft_espi.cpp:11:10: fatal error: TFT_eSPI.h: No such file or directory
* Looking for TFT_eSPI.h dependency? Check our library registry!
* CLI  > platformio lib search "header:TFT_eSPI.h"
* Web  > https://registry.platformio.org/search?q=header:TFT_eSPI.h
 #include <TFT_eSPI.h>
compilation terminated.
Compiling .pio\build\esp32\lib969\lvgl\drivers\glfw\lv_opengles_debug.c.o
Compiling .pio\build\esp32\lib969\lvgl\drivers\glfw\lv_opengles_driver.c.o
*** [.pio\build\esp32\lib969\lvgl\drivers\display\tft_espi\lv_tft_espi.cpp.o] Error 1
=========================================================== [FAILED] Took 230.78 seconds ===========================================================
 *  The terminal process "C:\Users\DanilinSergey\.platformio\penv\Scripts\platformio.exe 'run'" terminated with exit code: 1.
platformio.ini
	-DCORE_DEBUG_LEVEL=5
	-Os
lib_ldf_mode = deep+
	bodmer/TFT_eSPI@^2.5.43
	lvgl/lvgl@^9.2.2
	SPI
	SPIFFS
	FS
lv_tft_espi.cpp
 *      INCLUDES
#include "lv_tft_espi.h"
#if LV_USE_TFT_ESPI
main.cpp
#include <lvgl.h>
The library is connected. But the error does not disappear.
Change your platformio.ini to
  -Os
  lvgl/lvgl@^9.2.2
For configuring the TFT_eSPI library, please read TFT_eSPI/docs/PlatformIO/Configuring options.txt at master · Bodmer/TFT_eSPI · GitHub
You might have to switch the includes:
#include <lvgl.h>
Thank you! The problem has been solved.
