Trying to use platformio on vscode for the first time. I’ve tried to follow the solutions others have used for this problem with no success. Uninstalled both VS code and platformio multiple times. Deleted various folders as suggested.
main.cpp
pinMode(LED_BUILTIN,OUTPUT );
delay(1000);
delay(1000);
platform.ini
[env:d1_mini]
platform = espressif8266
board = d1_mini
C:\Users\KarlB\.platformio\packages\framework-arduinoespressif8266\cores\esp8266/FunctionalInterrupt.h:4:20: fatal error: stddef.h: No such file or directory
* Looking for stddef.h dependency? Check our library registry!
* CLI > platformio lib search "header:stddef.h"
* Web > https://platformio.org/lib/search?query=header:stddef.h
#include <stddef.h>
compilation terminated.
*** [.pio\build\d1_mini\FrameworkArduino\IPAddress.cpp.o] Error 1
*** [.pio\build\d1_mini\FrameworkArduino\FunctionalInterrupt.cpp.o] Error 1
In file included from C:\Users\KarlB\.platformio\packages\framework-arduinoespressif8266\cores\esp8266\HardwareSerial.cpp:26:0:
C:\Users\KarlB\.platformio\packages\framework-arduinoespressif8266\tools\sdk\libc\xtensa-lx106-elf\include/stdlib.h:16:20: fatal error: stddef.h: No such file or directory
#include <stddef.h>
In file included from C:\Users\KarlB\.platformio\packages\framework-arduinoespressif8266\cores\esp8266/Arduino.h:27:0,
from C:\Users\KarlB\.platformio\packages\framework-arduinoespressif8266\cores\esp8266\MD5Builder.cpp:1:
#include <stddef.h>
In file included from C:\Users\KarlB\.platformio\packages\framework-arduinoespressif8266\cores\esp8266\Print.cpp:24:0:
#include <stddef.h>
In file included from C:\Users\KarlB\.platformio\packages\framework-arduinoespressif8266\cores\esp8266\Schedule.cpp:4:0:
C:\Users\KarlB\.platformio\packages\framework-arduinoespressif8266\cores\esp8266\Schedule.h:4:22: fatal error: functional: No such file or directory
#include <functional>
*** [.pio\build\d1_mini\FrameworkArduino\MD5Builder.cpp.o] Error 1
*** [.pio\build\d1_mini\FrameworkArduino\Schedule.cpp.o] Error 1
*** [.pio\build\d1_mini\FrameworkArduino\HardwareSerial.cpp.o] Error 1
*** [.pio\build\d1_mini\FrameworkArduino\Print.cpp.o] Error 1
from C:\Users\KarlB\.platformio\packages\framework-arduinoespressif8266\cores\esp8266\Stream.cpp:23:
#include <stddef.h>
In file included from C:\Users\KarlB\.platformio\packages\framework-arduinoespressif8266\cores\esp8266\StackThunk.cpp:28:0:
#include <stddef.h>
*** [.pio\build\d1_mini\FrameworkArduino\Stream.cpp.o] Error 1
*** [.pio\build\d1_mini\FrameworkArduino\StackThunk.cpp.o] Error 1
from C:\Users\KarlB\.platformio\packages\framework-arduinoespressif8266\cores\esp8266\StreamString.cpp:23:
#include <stddef.h>
In file included from C:\Users\KarlB\.platformio\packages\framework-arduinoespressif8266\cores\esp8266\Arduino.h:27:0,
from C:\Users\KarlB\.platformio\packages\framework-arduinoespressif8266\cores\esp8266\Tone.cpp:24:
#include <stddef.h>
*** [.pio\build\d1_mini\FrameworkArduino\Tone.cpp.o] Error 1
*** [.pio\build\d1_mini\FrameworkArduino\StreamString.cpp.o] Error 1
=================================================================== [FAILED] Took 0.80 seconds ===================================================================
The terminal process "C:\Users\KarlB\.platformio\penv\Scripts\platformio.exe 'run'" terminated with exit code: 1.
> Executing task: C:\Users\KarlB\.platformio\penv\Scripts\platformio.exe run <
Processing d1_mini (platform: espressif8266; board: d1_mini; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/d1_mini.html
PLATFORM: Espressif 8266 (2.3.3) > WeMos D1 R2 and mini
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
- framework-arduinoespressif8266 3.20603.200130 (2.6.3)
- tool-esptool 1.413.0 (4.13)
- tool-esptoolpy 1.20800.0 (2.8.0)
- toolchain-xtensa 2.40802.191122 (4.8.2)
Found 29 compatible libraries
Compiling .pio\build\d1_mini\src\main.cpp.o
Compiling .pio\build\d1_mini\FrameworkArduino\Esp-frag.cpp.o
Compiling .pio\build\d1_mini\FrameworkArduino\Esp-version.cpp.o
Compiling .pio\build\d1_mini\FrameworkArduino\Esp.cpp.o
from src\main.cpp:1:
#include <stddef.h>
Compiling .pio\build\d1_mini\FrameworkArduino\FS.cpp.o
Compiling .pio\build\d1_mini\FrameworkArduino\FSnoop.cpp.o
In file included from C:\Users\KarlB\.platformio\packages\framework-arduinoespressif8266\cores\esp8266\umm_malloc/umm_malloc_cfg.h:11:0,
from C:\Users\KarlB\.platformio\packages\framework-arduinoespressif8266\cores\esp8266\umm_malloc/umm_malloc.h:14,
from C:\Users\KarlB\.platformio\packages\framework-arduinoespressif8266\cores\esp8266\Esp-frag.cpp:21:
C:\Users\KarlB\.platformio\packages\framework-arduinoespressif8266\cores\esp8266/debug.h:4:20: fatal error: stddef.h: No such file or directory
#include <stddef.h>
Compiling .pio\build\d1_mini\FrameworkArduino\FunctionalInterrupt.cpp.o
Compiling .pio\build\d1_mini\FrameworkArduino\HardwareSerial.cpp.o
Compiling .pio\build\d1_mini\FrameworkArduino\IPAddress.cpp.o
Compiling .pio\build\d1_mini\FrameworkArduino\MD5Builder.cpp.o
from C:\Users\KarlB\.platformio\packages\framework-arduinoespressif8266\cores\esp8266\Esp-version.cpp:21:
#include <stddef.h>
Compiling .pio\build\d1_mini\FrameworkArduino\Print.cpp.o
Compiling .pio\build\d1_mini\FrameworkArduino\Schedule.cpp.o
Compiling .pio\build\d1_mini\FrameworkArduino\StackThunk.cpp.o
from C:\Users\KarlB\.platformio\packages\framework-arduinoespressif8266\cores\esp8266\Esp.h:24,
from C:\Users\KarlB\.platformio\packages\framework-arduinoespressif8266\cores\esp8266\Esp.cpp:21:
#include <stddef.h>
Compiling .pio\build\d1_mini\FrameworkArduino\Stream.cpp.o
Compiling .pio\build\d1_mini\FrameworkArduino\StreamString.cpp.o
In file included from C:\Users\KarlB\.platformio\packages\framework-arduinoespressif8266\cores\esp8266\FS.h:24:0,
from C:\Users\KarlB\.platformio\packages\framework-arduinoespressif8266\cores\esp8266\FS.cpp:21:
Compiling .pio\build\d1_mini\FrameworkArduino\Tone.cpp.o
c:\users\karlb\.platformio\packages\toolchain-xtensa\xtensa-lx106-elf\include\c++\4.8.2\memory:62:31: fatal error: bits/stl_algobase.h: No such file or directory
#include <bits/stl_algobase.h>
*** [.pio\build\d1_mini\src\main.cpp.o] Error 1
*** [.pio\build\d1_mini\FrameworkArduino\Esp-frag.cpp.o] Error 1
*** [.pio\build\d1_mini\FrameworkArduino\Esp-version.cpp.o] Error 1
*** [.pio\build\d1_mini\FrameworkArduino\Esp.cpp.o] Error 1
*** [.pio\build\d1_mini\FrameworkArduino\FS.cpp.o] Error 1
In file included from C:\Users\KarlB\.platformio\packages\framework-arduinoespressif8266\cores\esp8266\FunctionalInterrupt.cpp:1:0:
#include <stddef.h>
In file included from C:\Users\KarlB\.platformio\packages\framework-arduinoespressif8266\cores\esp8266/FS.h:24:0,
from C:\Users\KarlB\.platformio\packages\framework-arduinoespressif8266\cores\esp8266\FSnoop.cpp:6:
#include <stddef.h>
*** [.pio\build\d1_mini\FrameworkArduino\FSnoop.cpp.o] Error 1
#include <stddef.h>
from C:\Users\KarlB\.platformio\packages\framework-arduinoespressif8266\cores\esp8266\IPAddress.cpp:20:
#include <stddef.h>
#include <stddef.h>
#include <stddef.h>
#include <stddef.h>
#include <stddef.h>
#include <stddef.h>
=================================================================== [FAILED] Took 0.76 seconds ===================================================================
