installed a couple Libs with Lib Manager and include them, but I get an Error while Build. The file is definitely in .platformio\lib\LiquidCrystal ID 136.
How can I solve that?
Win10 Build 1607
IDE 1.6.0 | CLI 3.1.0
Win10 Build 1607
Please provide an output of
pio lib list
pio lib -g list
pio run -v
I’ve just tested this library and it works a good for me PlatformIO + LiquidCrystal - Pastebin.com.
Hey, yeah this lib is working with Arduino IDE as well as Visual Studio perfectly. I guess it’s not the lib but some bug in the PlatformIO Software. Something related to this issue https://github.com/platformio/platformio/issues/195
It works with PlatformIO IDE too. See my post above. Could you share a test project for reproducing?
Project and external libs for .platformio\lib
Have you found something?
It’s OK that it doesn’t work. You broke the LiquidCrystal library with changing structure.
I’ve just removed your LiquidCrystal and install official from PlatformIO Library Registry. The project has been built successfully.
It will save your and our time. Thanks.
Thank you very much!
hai, i wanna ask why i got error no such file or directory? for this command
#include <LiquidCrystal_I2C.h>
how to solve that?
window 10
arduino 1.8.13
hai, i wanna ask why lcd.init (); is error? it says
error: ‘class LiquidCrystal_I2C’ has no member named ‘init’
lcd.init(); // initializing the LCD
how to solve that?
Please don’t revive 5 year old topics. Create a new one with the full platformio.ini
and the code of the project.
