Hi, there
I was import the libraries and check files but still the problem
src/main.cpp:91:10: fatal error:ESPASyncWebServer.h: No such file or directory
I try to make a new project with the libraries, don’t work !
Is there anything I’m missing here?
Hi ismael!
If your project is not for ESP-home, I suggest starting with the smallest possible project in terms of ESPAsyncWebServer. To do this, use the original library and start with the simple-server example.
platformio.ini
[env:thing]
platform = espressif8266
board = thing
https://github.com/me-no-dev/ESPAsyncWebServer
You don’t need AsyncTCP in your lib_deps. This will be installed autmatically by ESPAsyncWebServer.
Please post error logs, code / content of platformio.ini
as preformatted text instead of screenshots. To do this, simply click the </>
icon in the toolbar and paste your content between the three backticks:
type or paste code here
Thank you I migrated from Arduino to platformio and I couldnt fix until now. I still dont get why it does not recognize these libraries but at least I can get it to work
Did you initially installed the library via the library manager?
If you search the library registry (PlatformIO-Home / Libraries) for ESPAsyncWebserver, there are multiple matches. Unfortunately the original library is not the first one in the list.
This is the correct one:
