Fatal error: ESP8266WiFi.h: No such file or directory
cannot build project with ESP Async Webserver
platformio.ini
platform = espressif8266
board = nodemcuv2
    ESP Async WebServer
Error log:
Compiling .pio\build\nodemcuv2\FrameworkArduino\Esp-frag.cpp.o
Compiling .pio\build\nodemcuv2\FrameworkArduino\Esp-version.cpp.o
*** [.pio\build\nodemcuv2\lib039\WifiManager_ID567\WiFiManager.cpp.o] Error 1
=================================================================================================== [FAILED] Took 1.59 seconds ===================================================================================================
> Executing task in folder blink: C:\Users\140bpmdubstep\.platformio\penv\Scripts\platformio.exe run <
Processing nodemcuv2 (platform: espressif8266; board: nodemcuv2; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/nodemcuv2.html
PLATFORM: Espressif 8266 2.3.1 > NodeMCU 1.0 (ESP-12E Module)
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
PACKAGES: toolchain-xtensa 2.40802.191122 (4.8.2), framework-arduinoespressif8266 2.20602.191128 (2.6.2), tool-esptool 1.413.0 (4.13), tool-esptoolpy 1.20800.0 (2.8.0)
Found 34 compatible libraries
|-- <ESP Async WebServer> 1.2.3 #f13685e
|   |-- <ESPAsyncTCP> 1.2.2 #1547686
|   |-- <Hash> 1.0
Compiling .pio\build\nodemcuv2\src\main.cpp.o
Generating LD script .pio\build\nodemcuv2\ld\local.eagle.app.v6.common.ld
Compiling .pio\build\nodemcuv2\lib6a6\ESPAsyncTCP\AsyncPrinter.cpp.o
Compiling .pio\build\nodemcuv2\lib6a6\ESPAsyncTCP\ESPAsyncTCP.cpp.o
Compiling .pio\build\nodemcuv2\lib6a6\ESPAsyncTCP\ESPAsyncTCPbuffer.cpp.o
Compiling .pio\build\nodemcuv2\lib6a6\ESPAsyncTCP\SyncClient.cpp.o
Compiling .pio\build\nodemcuv2\lib6a6\ESPAsyncTCP\tcp_axtls.c.o
Compiling .pio\build\nodemcuv2\lib643\Hash\Hash.cpp.o
Compiling .pio\build\nodemcuv2\libec9\ESP Async WebServer\AsyncEventSource.cpp.o
In file included from .pio\libdeps\nodemcuv2\ESP Async WebServer\src\AsyncEventSource.h:31:0,
                 from .pio\libdeps\nodemcuv2\ESP Async WebServer\src\AsyncEventSource.cpp:21:
.pio\libdeps\nodemcuv2\ESP Async WebServer\src/ESPAsyncWebServer.h:35:25: fatal error: ESP8266WiFi.h: No such file or directory
* Looking for ESP8266WiFi.h dependency? Check our library registry!
* CLI  > platformio lib search "header:ESP8266WiFi.h"
* Web  > https://platformio.org/lib/search?query=header:ESP8266WiFi.h
 #include <ESP8266WiFi.h>
compilation terminated.
*** [.pio\build\nodemcuv2\libec9\ESP Async WebServer\AsyncEventSource.cpp.o] Error 1
=================================================================================================== [FAILED] Took 3.07 seconds ===================================================================================================
ESP8266 NodeMcu V3 board
Extend your platformio.ini file with one more library. Then it should work.
    ESP Async WebServer
    ESP8266WiFi
This answer is the suitable to this question :
