Hi
I am doing my first program.
I installed the EEPROMEx library and in the platformio.ini file it has the following:
[env: esp32doit-devkit-v1]
board = esp32doit-devkit-v1
# Using a library name
EEPROMEx
# ... or using library Id
170
# ... or depend on a specific version
EEPROMEx @ 09d7586108
When compiling it says:
In file included from C: \ Users \ fgarz \ .platform \ lib \ EEPROMEx_ID170 \ EEPROMex.cpp: 23: 0:
C: \ Users \ fgarz \ .platformio \ lib \ EEPROMEx_ID170 \ EEPROMex.h: 29: 24: fatal error: avr / eeprom.h: No such file or directory
compilation terminated.
*** [.pio \ build \ esp32doit-devkit-v1 \ lib377 \ EEPROMEx_ID170 \ EEPROMex.cpp.o] Error 1
Where can I get the eeprom.h file and where should I install it?
Thank you
