I have to correct my statement.
Both LED_BUILTIN and RGB_BUILTIN work perfectly.
Problems with LED asideâŚ
Here is a quick run down how to fix the upload problems
The default macOS driver seems to have a problem with the CH34x chipset/board.
You have to install the CH34xVCPDriver.
If you are on a M1/M2 ARM machine you need to install and use the app from the DMG. On Intel the pkg seems to do the trick.
What is a little weird is that I donât see the driver loaded:
kextstat | grep -v apple
Executing: /usr/bin/kmutil showloaded
No variant specified, falling back to release
Index Refs Address Size Wired Name (Version) UUID <Linked Against>
and that it now creates two ports.
One seems to be the old driver, the other one the new driver.
$ pio device list
/dev/cu.wchusbserial57810170451
Hardware ID: USB VID:PID=1A86:55D3 SER=5781017045 LOCATION=2-1
Description: USB Single Serial
/dev/cu.usbmodem57810170451
You need to ensure that pio uses the wch port.
This pio ini now solved the upload for me:
[env:esp32-s3-devkitc1-n16r8]
board = esp32-s3-devkitc1-n16r8
upload_port = /dev/cu.wchusbserial*
bridgeb: I have found a brand new ESP32-S3 N16S8 sown in the above image. I am running Platformio on a Windows 10 laptop.
How did you get that to work? Iâve got an ESP32-S3-devkitC-1-N8, but whenever I try to create a PlatformIO project for it in VSC, all I get is:
Installing espressif/toolchain-riscv32-esp @ 8.4.0+2021r2-patch3
UnknownPackageError: Could not find the package with âespressif/toolchain-riscv32-esp @ 8.4.0+2021r2-patch3â requirements for your system âwindows_amd64â
Your comments would be appreciated!
The risc toolchain is for ESP32-C series!?
Please share your platformio.ini
nmw01223: sivar2311 is right. You should be seeing it use the xtensa-esp32s3 toolchain not the risc toolchain. When choosing the board for the project make sure you select one of the esp32-s3-devkitc-1 board options. The default setting is for 8MB of memory but will still work. To make full use of the 16MB flash and 8MB PSRAM you will need to decide on a partition model for the application.
I picked up on this because at the time I couldnât get anything to work. When I selected the ESP32-S3-DEVKITC-1-N8, being what I have, it came up with the message above.
So, I tried a bland ESP32 dev board and it created the project OK but would not upload because it said wrong CPU - correct, I assume.
Then in another thread someone suggested deleting the espressif folder in the .platformio tree on the basis that it might be out of date and referencing something now non-existent in the repository. So, did that, it presumably reinstalled, and miraculously the project created correctly and all is now OK. So, I assume he was right.
Hey tcurdt thanks so much. I had the exact same problem and the driver solved it. I canât imaging how long I would have been beating my head against the wall trying to solve this.
2019 Intel Macbook Pro.
@tcurdt Thank you very much for sharing the steps to solve your issue.
I am in the same situation you were in and downloaded the drivers and installed them from the DMG, but when i run the programm and click the install button nothing happens:
I wanted to ask if the installer might be broken for me and if i should see anything after clicking Install
In the folder with the DMG and PKG is also an instrucitons.pdf that contains some interesting additional information. After some instructions for installing there are some steps for validation:
When plug the USB-to-SERIAL device into the USB port, you can open âSystemReportâ->Hardware->USB, the right side is âUSB Device Treeâ and you will find a device whose âVendor IDâ is [0x1a86] if USB device is working properly.
I can indeed see the USB device with vendor ID 0x1a86. But the next step -
Open âTerminalâ program under Applications-Utilities folder and type the command âls /dev/tty*â. You should see the âtty.wchusbserialxâ where âxâ is the assigned device number similar to Windows COM port assignment.
fails for me. I cannot see any wchusbserial port.
Does someone know what might be the issue here?
This ended up working for me! (Iâm using a Waveshare ESP32S3 Board with a 1.28 Touch LCD - the link to their wiki is here on an M1 MacBook Pro and using the Arduino IDE)). I got it to recognize the board exactly once and then upload my code. I changed it a bit and now itâs not communicating any more, so Iâm troubleshooting that, BUT I got the driver installed. Also, I tend to give more info than not enough in the hopes it helps someone who doesnât know what theyâre doing (cause Iâm totally in the same boat lol) so forgive me if I share more than needed.
Driver installation:
First, make sure you can use System Extensions and third party drivers. (You can do that in Recovery Mode under Startup Security Utility).
Next, youâll open terminal and use it to copy the .dext file to the extensions directory.
After downloading the driver, mount the .dmg and get to the blue icon for the driver installer.
Right click the installer icon and select âShow Package Contentsâ
Navigate to âContents â MacOS â Library â SystemExtensionsâ. Youâll see the ch.wch.CH34xVCPDriver.dext file there.
Change the terminal directory to the above System Extensions folder. Use the âcdâ command and drag and drop the âSystemExtensionsâ folder to the terminal to automatically enter the path. It should look something like:
bobross@MacBook-Pro ~ % cd /Volumes/CH34xVCPDriver/CH34xVCPDriver.app/Contents/Library/SystemExtensions -
Hit the enter key and youâll now be in the correct directory. Terminal should now show:
bobross@MacBook-Pro SystemExtensions %
Now that youâre in the right directory, run the following command:
sudo cp -r /cn.wch.CH34xVCPDriver.dext/ /Library/DriverExtensions
Now that the file is copied, we need to load the extension using this command:
systemextensionsctl install /Library/DriverExtensions/cn.wch.CH34xVCPDriver.dext
Thatâll put it in the right area - like the install was supposed to.
It should prompt you to Approve the System Extension - if it doesnât, go to System Preferences â General â Login Items & Extensions â Extensions â Driver Extensions" (its ALLLL the way at the bottom of the window). Click on the âiâ in the circle. Toggle the switch for the CH34xVCPDriver option. Click Done.
Restart you computer.
Now all you have to do is verify the installation! Run this command in Terminal:
systemextensionsctl list
Youâll get something back that looks like this:
4 extension(s)
--- com.apple.system_extension.driver_extension (Go to 'System Settings > General > Login Items & Extensions > Driver Extensions' to modify these system extension(s))
enabled active teamID bundleID (version) name [state]
5JZGQTGU4W cn.wch.CH34xVCPDriver (1.0/1) cn.wch.CH34xVCPDriver [activated enabled]
52444FG85C com.silabs.cp210x (6.0.2/1) com.silabs.cp210x [activated waiting for user]
If it shows [activated enabled] youâre good! You should see both wchusbserial and usbmodem now when looking at the port list.
I was about to give up and get my windows laptop out, thank you for this, really worked a treat.
Im on 15.0.1 of macos and the install never prompted for the activation. With your description I was able to find the extension enable slider in settings and it works
This worked for me. It was the treasure found after a very long quest. Thank you very much!
Thanks! This is the right answer for Mac users.
installing the ch34x drivers and selecting the serial port worked for me.
you can also brew install the drivers:
brew install --cask wch-ch34x-usb-serial-driver
you will get a pop-up to enable the extension, follow the instructions and enable it.
I got it working. I used to have this error when trying to upload an image using ESP-IDF
Failed to write to target RAM (result was 0107: Checksum error)
I downloaded the CH341SER_MAC driver, unzipped it, and ran the .dmg installer to install the app
I opened CH34xVCPDriver.app and clicked the Install button
In the dialog i confirmed that i want to install the driver extension
I enabled the extension: System Preferences â General â Login Items & Extensions â Extensions I clicked the â next to Driver extensions
I restarted my computer
To confirm that the driver is working, I connected the ESP32-S3 via usb and checked if thereâs a device named /dev/tty.wchusbserial* or /dev/cu.wchusbserial*.
Now images upload to my S3 board without any issues.
