I cannot upload project to NodeMCUv2, on Windows I have only one response, and on mac I have 3 response alternately, but I can only erase flash on both OS.
How i can fix it.
Thanks.
PS. Sory for my bad English.
How i can fix it.
Thanks.
For your Mac errors
Auto-detected: /dev/cu.SLAB_USBtoUART
"/System/Library/Frameworks/Python.framework/Versions/2.7/Resources/Python.app/Contents/MacOS/Python" "/Users/mikolaj/.platformio/packages/tool-esptoolpy/esptool.py" --chip esp8266 --port "/dev/cu.SLAB_USBtoUART" --baud 115200 write_flash 0x0 .pio/build/nodemcuv2/firmware.bin
esptool.py v2.8
Serial port /dev/cu.SLAB_USBtoUART
File "/Users/mikolaj/.platformio/packages/tool-esptoolpy/esptool.py", line 3201, in <module>
_main()
File "/Users/mikolaj/.platformio/packages/tool-esptoolpy/esptool.py", line 3194, in _main
main()
File "/Users/mikolaj/.platformio/packages/tool-esptoolpy/esptool.py", line 2889, in main
esp = chip_class(each_port, initial_baud, args.trace)
File "/Users/mikolaj/.platformio/packages/tool-esptoolpy/esptool.py", line 237, in __init__
self._port = serial.serial_for_url(port)
File "/Library/Python/2.7/site-packages/serial/__init__.py", line 88, in serial_for_url
instance.open()
File "/Library/Python/2.7/site-packages/serial/serialposix.py", line 272, in open
self._reconfigure_port(force_update=True)
File "/Library/Python/2.7/site-packages/serial/serialposix.py", line 438, in _reconfigure_port
[iflag, oflag, cflag, lflag, ispeed, ospeed, cc])
termios.error: (22, 'Invalid argument')
*** [upload] Error 1
esptool.py v2.8
Connecting........_____....._____....._____....._____....._____....._____....._____
A fatal error occurred: Failed to connect to ESP8266: Timed out waiting for packet header
Compressed 284656 bytes to 206875...
Writing at 0x00004000... (15 %)
A fatal error occurred: Timed out waiting for packet header
seems like it’s properly interacting with the serial. Does adding a slower baud rate like upload_speed = 9600 in the platformio.ini make a difference? A different USB port, or a different cable?
For Windows:
|-- <WiFi> 1.2.7 (C:\Users\Mikolaj98p\.platformio\lib\WiFi_ID870)
WiFiClient.cpp:(.text._ZN10WiFiClient6statusEv+0x0): multiple definition of `WiFiClient::status()'; .pio\build\nodemcuv2\lib4bf\libWiFi_ID870.a(WiFiClient.cpp.o):WiFiClient.cpp:(.text._ZN10WiFiClient6statusEv+0x4): first defined here
You have globally installed the “WiFi” library in PlatformIO. This is wrong for the ESP8266. Either uninstall this library from the global platform storage (delete C:\Users\Mikolaj98p\.platformio\lib\WiFi_ID870) or add lib_ignore = WiFi in the platformio.ini in the project.
In platformio.ini:
[env:nodemcuv2]
platform = espressif8266
board = nodemcuv2
166
On windows working.
