I was tried to upload the default blink example for esp8266 to my ESP-01 using platformIO, but it seems doen’t work, here’s the Hardware I used: two different USB downloaders, both’s chip is CH340, 4 ESP-01 and 2 ESP-01S
Software I used: I tried to set ESP-01 512K and ESP-01 1M in platformIO and the framework is arduino
The situation is I looked up in the forum, the problem is seems like CH340 chip can not work on high baud rate, so I tried to change the rate in many diffent value: I tried 115200 and higher, and also tried 28000 and lower, but both of ways did not work, the platformIO showed :
Connecting…………………_____
A fatal error occurred: Failed to connect to ESP8266: Timed out waiting for packet header
(I tried to press RST pin on USB downloader, but still doen’t work)
Then I tried 57600 and 74880, the LED on ESP-01 blinked rapidly but finally failed to uploader, and platformIO showed:
A fatal error occurred: Failed to connect to ESP8266: Invalid head of packet (0x08)
even this only happed for few times, and rest fo the time it just told me time out
I thought it is the chip’s problem, but I can upload the program by using Arduino IDE with 115200 baud rate and higher successfully.
