I’m receiving the above error when trying to start the Unified Debugger on an nRF52. I had this working in the past on the nRF52 but when I created a new project I can’t get the debugger to start.
I’m also receiving the warnings:
Cannot insert breakpoint 1.
Cannot access memory at address 0x26334
My program is just the default null project with empty setup() { } and loop() { } procedures.
This is the complete log:
0x02a000a0 in ?? ()
Select auto target interface speed (2000 kHz)
Resetting target
Loading section .text, size 0x84ac lma 0x26000
Loading section .ARM.exidx, size 0x8 lma 0x2e4ac
Loading section .data, size 0x23c lma 0x2e4b4
Start address 0x262b8, load size 34544
Transfer rate: 16867 KB/sec, 6908 bytes/write.
Temporary breakpoint 1 at 0x26334: file /Users/chrisgr/.platformio/packages/framework-arduinoadafruitnrf52/cores/nRF5/main.cpp, line 75.
PlatformIO: Resume the execution to
debug_init_break = tbreak mainPlatformIO: More configuration options → Redirecting...
Warning:
Command aborted.
