I am trying to develop MSP430F5529 on pio.And the code can be built and upload well.But I can not debug correctly.When I click the “DEBUG”,the Terminal show “SUCCESS”,just like this.
However,nothing happened.I can not read the data of MCU.later an error is happened.It tells “Failed to launch GDB”,just like this.
Can anyone tell me what should I do?
By the way,It seems my driver is installed correctly.
(upload://xNuZ9viiEmPiObCddFGi8wB2gZN.png)
My system is Windows10
The version of platformio Core is 5.1.1
The version of platformio Home is 3.3.4
It seems I can only upload one picture,
here is my second photo
Processing lpmsp430f5529 (platform: timsp430; board: lpmsp430f5529; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/timsp430/lpmsp430f5529.html
PLATFORM: TI MSP430 (2.3.0) > TI LaunchPad MSP-EXP430F5529LP
HARDWARE: MSP430F5529 25MHz, 8KB RAM, 47KB Flash
DEBUG: Current (mspdebug) On-board (mspdebug)
- framework-energiamsp430 1.10810.210219 (1.8.10)
- toolchain-timsp430 1.40603.210219 (4.6.3)
Converting sketch_oct27a.ino
Found 18 compatible libraries
Building in debug mode
Compiling .pio\build\lpmsp430f5529\src\sketch_oct27a.ino.cpp.o
C:/Users/sakihata/Documents/PlatformIO/Projects/211030-001141-lpmsp430f5529/src/sketch_oct27a.ino: In function 'void setup()':
C:/Users/sakihata/Documents/PlatformIO/Projects/211030-001141-lpmsp430f5529/src/sketch_oct27a.ino:28:35: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
C:/Users/sakihata/Documents/PlatformIO/Projects/211030-001141-lpmsp430f5529/src/sketch_oct27a.ino:30:33: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
C:/Users/sakihata/Documents/PlatformIO/Projects/211030-001141-lpmsp430f5529/src/sketch_oct27a.ino:35:35: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
C:/Users/sakihata/Documents/PlatformIO/Projects/211030-001141-lpmsp430f5529/src/sketch_oct27a.ino:37:33: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
C:/Users/sakihata/Documents/PlatformIO/Projects/211030-001141-lpmsp430f5529/src/sketch_oct27a.ino:47:38: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
C:/Users/sakihata/Documents/PlatformIO/Projects/211030-001141-lpmsp430f5529/src/sketch_oct27a.ino:50:24: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
Linking .pio\build\lpmsp430f5529\firmware.elf
Checking size .pio\build\lpmsp430f5529\firmware.elf
Building .pio\build\lpmsp430f5529\firmware.hex
RAM: [ ] 2.1% (used 170 bytes from 8192 bytes)
Flash: [== ] 16.7% (used 8042 bytes from 48128 bytes)
========================= [SUCCESS] Took 13.47 seconds =========================
MSPDebug version 0.24 - debugging tool for MSP430 MCUs
Copyright (C) 2009-2016 Daniel Beer <dlbeer@gmail.com>
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
----------------- NOTE ------------------
Modified version of mspdebug for Energia
Do not use standalone
Chip info database from MSP430.dll v3.3.1.4 Copyright (C) 2013 TI, Inc.
Using new (SLAC460L+) API
MSP430_GetNumberOfUsbIfs
MSP430_GetNameOfUsbIf
Found FET: COM7
MSP430_Initialize: COM7
FET firmware update is required.
Re-run with --allow-fw-update to perform a firmware update.
undefinedtilib: device initialization failed
Reading symbols from C:\Users\sakihata\Documents\PlatformIO\Projects\211030-001141-lpmsp430f5529\.pio\build\lpmsp430f5529\firmware.elf...
done.
PlatformIO: debug_tool = mspdebug
:2000: �������ӷ���һ��ʱ���û����ȷ�����ӵ�����û�з�Ӧ�����ӳ���ʧ�ܡ�
Well that is… definitely weird. Seems like a file is corrupted with a wrong file encoding.
Thereis an issue open with .pioinit:11: Error in sourced command file: but it has a “Remote register badly formatted” error following it, not this complete gibberish.
Also doesn’t look good.
You should open an issue at Issues · platformio/platform-timsp430 · GitHub.
thanks a lot,I have already open a new issue
