first, I noticed that some other people complain from the same problem of mine and I tried to follow the replies but it didn’t help me to resolve my problem, so I created another thread.
Anyway, I’m using nodeMCU so i’m using the nodeMCU for programming while the PlatformIO debugger for debugging. and i’m able to download the flashing program and the LED is blinking properly (but I have to unplug the PlatformIO debugger to be able to download the binary file) but i had no luck to run the debugger and i’m getting the below errors.
and the content of the platformio.ini is:
[env:esp wrover kit]
; https://docs.espressif.com/projects/esp-idf/en/latest/get-started/get-started-wrover-kit.html#rgb-led
-D LED_BUILTIN=2
upload_port = COM9
monitor_port = COM9
debug_tool = esp-prog
debug_speed = 500
