I’m encountering an issue with debugging my Arduino Uno R3 using PlatformIO in VS Code. I’m using the basic “Blink” sketch, which works perfectly fine in Arduino IDE. However, when I try to run the same code in VS Code with PlatformIO, it uploads successfully, and the PIO Device Monitor also works as expected.
The problem arises a few seconds later, when I get an error message stating:
“Failed to launch GDB: .pioinit:13: Error in sourced command file: :3333: The system has attempted to mount a drive to a directory that is already mounted.”
Steps I’ve tried so far:
- Reinstalling PlatformIO completely.
- Modifying the
platformio.inifile in various ways. - Modifying the
launch.jsonfile to adjust debugger settings. - Checking for duplicate debugger instances via the command window, but there were none.
- Verifying if another process is using the same port, but nothing seems to be conflicting.
- Suspecting it was a permissions issue, I ran VS Code (actually Cursor) as an administrator to see if that helped.
- Disabled my antivirus in case it was interfering with the debugging process.
Since Arduino IDE does not have a debugger, I suspect that the issue is specific to PlatformIO’s debugging setup. The program works fine until the debugger is launched, which suggests that the debugger is trying to attach to a resource that is already in use.
I’m not sure what else to try at this point. Could this be a bug, or is there a specific configuration I need to change? Any guidance would be greatly appreciated.
This is the whole message
Processing uno (platform: atmelavr; board: uno; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/uno.html
PLATFORM: Atmel AVR (5.1.0) > Arduino Uno
DEBUG: Current (avr-stub) External (avr-stub, simavr)
- framework-arduino-avr @ 5.2.0
- tool-avrdude @ 1.60300.200527 (6.3.0)
Found 7 compatible libraries
|-- Servo @ 1.2.2
|-- SmartRobotCarKitV4 @ 1.0.0
Building in debug mode
Checking size .pio\build\uno\firmware.elf
RAM: [ ] 0.4% (used 9 bytes from 2048 bytes)
Flash: [= ] 5.9% (used 1896 bytes from 32256 bytes)
AVAILABLE: arduino
Looking for upload port...
Auto-detected: COM19
Uploading .pio\build\uno\firmware.hex
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file ".pio\build\uno\firmware.hex"
avrdude: writing flash (1896 bytes):
Writing | ################################################## | 100% 0.30s
avrdude: 1896 bytes of flash written
avrdude: verifying flash memory against .pio\build\uno\firmware.hex:
avrdude: load data flash data from input file .pio\build\uno\firmware.hex:
avrdude: input file .pio\build\uno\firmware.hex contains 1896 bytes
Reading | ################################################## | 100% 0.24s
avrdude: verifying ...
avrdude: 1896 bytes of flash verified
avrdude done. Thank you.
========================= [SUCCESS] Took 5.83 seconds =========================
Reading symbols from C:\Users\34697\Documents\PlatformIO\Projects\Smaert\.pio\build\uno\firmware.elf...
done.
PlatformIO: debug_tool = avr-stub
:3333: El sistema ha intentado unir una unidad a un directorio de una unidad ya unida.
