"Failed to install Python dependencies into penv"
I am getting the following error every time PlatformIO tries to build anything:
Error: Failed to install Python dependencies (exit code: 2)
Error: Failed to install Python dependencies into penv
The error happens with any project, even a simple “esp32dev” test project using the official espressif32 platform. PlatformIO is unable to install its Python dependencies
into the virtual environment (penv) under any situation (my guess).
System details:
  • Operating System: Windows 11 x64
  • Python Version: 3.10.0
    Verified by:
    python --version → Python 3.10.0
    py --version → Python 3.10.0
    pip --version → pip 21.2.3 (Python 3.10)
  • PlatformIO Core Version: 6.1.18 (installed via “pip install platformio” and installer script)
  • PlatformIO Core Executable:
    C:\Users\joine\.platformio\penv\Scripts\platformio.exe
  • Python inside PlatformIO’s penv:
    C:\Users\joine\.platformio\penv\Scripts\python.exe
Full list of things I already tried:
  • Uninstalled PlatformIO completely with “pip uninstall platformio”
  • Deleted the entire folder: C:\Users\joine\.platformio
  • Reinstalled PlatformIO fresh with “pip install platformio” and installer script
  • Removed Python 3.13 from the system
  • Installed Python 3.10.0 cleanly and added it to PATH
  • Verified that Python, pip, and py all point to Python 3.10 and not Python 3.13
  • Confirmed that “pio --version” works and PlatformIO Core is functional
  • Confirmed that “pio system info” shows valid Python executable inside penv
Problem summary:
PlatformIO successfully creates penv, but fails when installing the Python dependencies into that environment.
The error always happens, no matter which project or which platform I use. The error message does not include
a detailed traceback, only:
project from building.
What’s the platformio.ini?
[common]
board = esp32-s3-devkitc-1
board_upload.flash_size = 16MB
board_build.partitions = partitions_16mb.csv
    NimBLE-Arduino@^1.4.3
    adafruit/Adafruit NeoPixel@^1.15.1
    bblanchon/ArduinoJson@^7.3.1
    nickgammon/Regexp@^0.1.0
    -D USE_NIMBLE
    -D CORE_DEBUG_LEVEL=0
[env:standard]
extends = common
    ${common.build_flags}
    -D STANDARD
    ${common.lib_deps}
It worked before but after reseting my PC somehow it started this weird stuff
Would be great if anyone could help, i sadly cant work on my projects anymore… :folded_hands:
All references I’m seeing to this are from PIOArduino (the espressif32 fork that has a more up-to-date Arduino core etc.), not from the official espressif32 platform.
In fact it’s printed right there
So that contradicts
Are you sure you have:
  • Installed the “PlatformIO IDE” extension in VSCode, not the PIOArduino extension?
  • If you want to use the official espressif32 platform, write platform = espressif32@6.12.0 instead of platform = espressif32 into your platformio.ini?
oh gosh you are right, after using platform = espressif32@6.12.0 it finally worked but now i have compiling issues since like you said i used a more newer version of arduino… is there any work around like almost every file has a error? thanks for the help sorry :folded_hands:
Please file an issue in https://github.com/pioarduino/platform-espressif32/issues if PIOArduino throws that Failed to install Python dependencies into penv error. Sadly the exception doesn’t print the exact cause (or the output from the command it tried…), so we can’t further analyze it.
Also make sure to fullfill the requirements. You definitely need git installed.
I checked their github and saw tons of open issues with that same error, im guessing its nothing new, tried also using some few old versions which also dosnt work right so weird honestly, but thank you so much and yes got git and all the requirements installed, i guess i need to recode some files, hope i dont have any big stuff gone. but thank you so much really helpful atleast i now have a different issue to work on haha :folded_hands::blush:
Where? There are only 4 open issues. The only direct reference to the error that I can find is
And if you want to use Pioarduino, it might be worth a try to install the PIOArduino extension instead of the PlatformIO IDE extension in VSCode, after of course deleting the entire .platformio folder again.
same issue here, pioarduino is unusable today
After talking to a PIOArduino moderator, he told me to first uninstall the PlatformIO folders and everything related, and then install the PIOArduino extension in VS Code. The extension installs all the required components that were probably missing when using the platform link or whatever.
But it worked after installing it through VS Code, I could use it in my IDE of choice (CLion). I had to recode most of the project since I now have the latest version of PIOArduino, with (I think) Arduino 3 or whatever, but yeah.
You should be aware of the Arduino framework version you are using.
You’ll see the the current version when you build the project:
You can select a specific version in the “platformio.ini” file by setting the desired version in the platform setting.
See GitHub - sivar2311/platform-espressif32-versions: A list of espressif32-platform versions for PlatformIO / pioarduino
You are right im using:
  • framework-arduinoespressif32 @ 3.3.4+sha.b859bdf
  • framework-arduinoespressif32-libs @ 5.5.0+sha.8410210c9a
this error continue to happen very often,
PlatformIO is becoming unusable…
If you want to get some help, you need to provide little more details like OS, Python version installed, used Editor, PlatformIO or Pioarduino and so on.
The error is well known and reproducible since months,
sometimes it happen, sometimes not.
sometimes GitHub stops responding to PlatformIO tools and PlatformIO became unusable with this error:
“Failed to install Python dependencies into penv”
This issue affect PioArduino too.
Yes, but it is a matter of different combinations like OS etc etc. I don’t have such issues. So let us know more details about your system / components used.
Windows 11 latest update,
platform = https://github.com/pioarduino/platform-espressif32/releases/download/55.03.36/platform-espressif32.zip
same problem on Linux Fedora/Ubuntu
Does this happen with the original PlatformIO and original Platform espressif32 platform?
Assuming that your using VS Code (not Clion or some other clones)
Again, this seems to be a matter of combinations. Means all the components you are using.
Afaik on linux you must install python3-venv.
