Failed to install PlatformIO IDE ([[object Object]]unable to get local issuer certificate)
Hi *,
I’m trying to install PlatformIO IDE on top of VSCode on an ubuntu 22.04.
VSCode is version 1.71 installed from tar.gz (not snap).
At my company we have a corporate proxy deciphering all the SSL protocol (for security reasons).
To avoid using the form “http://user:password@proxy:port” I’ve installed a CNTLM on my machine and I define my http[s]_proxy variables to “http://localhost:6633”
I’ve installed on my local machine the certificates needed to allow SSL traffic through the proxy in /usr/local/share/ca-certificates and issued a update-ca-certificates command.
When installing PlatformIO IDE from extensions mananager, I get an error : Failed to install PlatformIO IDE.
Developer tools/console shows :
Error: /home/cnes/marcosjl/.platformio/.cache/tmp/.piocore-installer-licuykob/tmp1u2vhrp6/pioinstaller.zip/urllib3/connectionpool.py:1043: InsecureRequestWarning: Unverified HTTPS request is being made to host 'localhost'. Adding certificate verification is strongly advised. See: https://urllib3.readthedocs.io/en/1.26.x/advanced-usage.html#ssl-warnings /home/cnes/marcosjl/.platformio/.cache/tmp/.piocore-installer-licuykob/tmp1u2vhrp6/pioinstaller.zip/urllib3/connectionpool.py:1043: InsecureRequestWarning: Unverified HTTPS request is being made to host 'localhost'. Adding certificate verification is strongly advised. See: https://urllib3.readthedocs.io/en/1.26.x/advanced-usage.html#ssl-warnin...
onDidChangeNotification @ notificationsAlerts.ts:42
console.ts:137 [Extension Host] rejected promise not handled within 1 second: RequestError: unable to get local issuer certificate
y @ console.ts:137
console.ts:137 [Extension Host] stack trace: RequestError: unable to get local issuer certificate
	at ClientRequest.<anonymous> (/home/cnes/marcosjl/.vscode/extensions/platformio.platformio-ide-2.5.4-linux-x64/node_modules/got/dist/source/core/index.js:970:111)
	at Object.onceWrapper (node:events:646:26)
	at ClientRequest.emit (node:events:538:35)
	at ClientRequest.emit (node:domain:475:12)
	at origin.emit (/home/cnes/marcosjl/.vscode/extensions/platformio.platformio-ide-2.5.4-linux-x64/node_modules/@szmarczak/http-timer/dist/source/index.js:43:20)
	at TLSSocket.socketErrorListener (node:_http_client:442:9)
	at TLSSocket.emit (node:events:526:28)
	at TLSSocket.emit (node:domain:475:12)
	at emitErrorNT (node:internal/streams/destroy:157:8)
	at emitErrorCloseNT (node:internal/streams/destroy:122:3)
	at process.processTicksAndRejections (node:internal/process/task_queues:83:21)
	at TLSSocket.onConnectSecure (node:_tls_wrap:1530:34)
	at TLSSocket._finishInit (node:_tls_wrap:944:8)
	at ssl.onhandshakedone (node:_tls_wrap:725:12)
y @ console.ts:137
$onExtensionRuntimeError @ mainThreadExtensionService.ts:79
mainThreadExtensionService.ts:80 RequestError: unable to get local issuer certificate
$onExtensionRuntimeError @ mainThreadExtensionService.ts:80
workbench.html:1 [.WebGL-0x153c01c50600]GL Driver Message (OpenGL, Performance, GL_CLOSE_PATH_NV, High): GPU stall due to ReadPixels
workbench.html:1 [.WebGL-0x153c01c50600]GL Driver Message (OpenGL, Performance, GL_CLOSE_PATH_NV, High): GPU stall due to ReadPixels (this message will no longer repeat)
contextKeyService.ts:452 Element already has context attribute: pane, expanded, horizontal
c @ contextKeyService.ts:452
Any hint really appreciated as this has worked on CentOS 7 machines…
Regards
José
And you set that URL as your proxy and disabled strict SSL per the documentation?
https://docs.platformio.org/en/latest/integration/ide/vscode.html#proxy-server-support
Hi
Yes. The settings.json file contains :
    "workbench.colorTheme": "Visual Studio Dark",
    "workbench.iconTheme": "vscode-icons",
    "C_Cpp.updateChannel": "Insiders",
    "cmake.configureOnOpen": false,
    "git.ignoreLegacyWarning": true,
    "telemetry.enableTelemetry": false,
    "telemetry.enableCrashReporter": false,
    "editor.wordWrap": "on",
    "http.proxyAuthorization": null,
    "http.systemCertificates": false,
    "http.proxyStrictSSL": false
I did a complete delete of all VScode and PlatformIO files and dir (.vscode, .config/Code, .platformio).
And again define proxy and set to false http.systemCertificates and http.proxyStrictSSL.
Unsuccessfully…
José
Maybe @ivankravets has an idea about these proxy settings?
I’ve tried to install pio core in CLI mode…
here is the command I used :
python3 -c "$(curl -fsSL https://raw.githubusercontent.com/platformio/platformio/develop/scripts/get-platformio.py)"
This command works fine on my CentOS 7 machine (with exactly the same setup : same CNTLM listening on localhost:6633, http_proxy and https_proxy variables, same certificates installed). But on Ubuntu, here is the output :
marcosjl@tu-ubuntuq-p01 tmp $ python3 -c "$(curl -fsSL https://raw.githubusercontent.com/platformio/platformio/develop/scripts/get-platformio.py)"
Installer version: 1.1.2
Platform: Linux-5.15.0-47-generic-x86_64-with-glibc2.35
Python version: 3.10.4 (main, Jun 29 2022, 12:14:53) [GCC 11.2.0]
Python path: /usr/bin/python3
Creating a virtual environment at /home/marcosjl/.platformio/penv
/usr/bin/python3
  File "/tmp/.piocore-installer-dq7l7zqj/tmp6y0ab_u8/pioinstaller.zip/urllib3/connectionpool.py", line 700, in urlopen
  File "/tmp/.piocore-installer-dq7l7zqj/tmp6y0ab_u8/pioinstaller.zip/urllib3/connectionpool.py", line 994, in _prepare_proxy
  File "/tmp/.piocore-installer-dq7l7zqj/tmp6y0ab_u8/pioinstaller.zip/urllib3/connection.py", line 414, in connect
  File "/tmp/.piocore-installer-dq7l7zqj/tmp6y0ab_u8/pioinstaller.zip/urllib3/util/ssl_.py", line 449, in ssl_wrap_socket
  File "/tmp/.piocore-installer-dq7l7zqj/tmp6y0ab_u8/pioinstaller.zip/urllib3/util/ssl_.py", line 493, in _ssl_wrap_socket_impl
  File "/usr/lib/python3.10/ssl.py", line 512, in wrap_socket
    return self.sslsocket_class._create(
  File "/usr/lib/python3.10/ssl.py", line 1070, in _create
    self.do_handshake()
  File "/usr/lib/python3.10/ssl.py", line 1341, in do_handshake
    self._sslobj.do_handshake()
ssl.SSLCertVerificationError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:997)
During handling of the above exception, another exception occurred:
  File "/tmp/.piocore-installer-dq7l7zqj/tmp6y0ab_u8/pioinstaller.zip/requests/adapters.py", line 440, in send
  File "/tmp/.piocore-installer-dq7l7zqj/tmp6y0ab_u8/pioinstaller.zip/urllib3/connectionpool.py", line 785, in urlopen
  File "/tmp/.piocore-installer-dq7l7zqj/tmp6y0ab_u8/pioinstaller.zip/urllib3/util/retry.py", line 592, in increment
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='api.registry.platformio.org', port=443): Max retries exceeded with url: /v3/packages/platformio/tool/python-portable (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:997)')))
  File "/tmp/tmpac9qs_43", line 68, in <module>
    main()
  File "/tmp/tmpac9qs_43", line 60, in main
    bootstrap()
  File "/tmp/tmpac9qs_43", line 46, in bootstrap
    pioinstaller.__main__.main()
  File "/tmp/.piocore-installer-dq7l7zqj/tmp6y0ab_u8/pioinstaller.zip/pioinstaller/__main__.py", line 133, in main
  File "/tmp/.piocore-installer-dq7l7zqj/tmp6y0ab_u8/pioinstaller.zip/click/core.py", line 1128, in __call__
  File "/tmp/.piocore-installer-dq7l7zqj/tmp6y0ab_u8/pioinstaller.zip/click/core.py", line 1053, in main
  File "/tmp/.piocore-installer-dq7l7zqj/tmp6y0ab_u8/pioinstaller.zip/click/core.py", line 1637, in invoke
  File "/tmp/.piocore-installer-dq7l7zqj/tmp6y0ab_u8/pioinstaller.zip/click/core.py", line 1395, in invoke
  File "/tmp/.piocore-installer-dq7l7zqj/tmp6y0ab_u8/pioinstaller.zip/click/core.py", line 754, in invoke
  File "/tmp/.piocore-installer-dq7l7zqj/tmp6y0ab_u8/pioinstaller.zip/click/decorators.py", line 26, in new_func
  File "/tmp/.piocore-installer-dq7l7zqj/tmp6y0ab_u8/pioinstaller.zip/pioinstaller/__main__.py", line 61, in cli
  File "/tmp/.piocore-installer-dq7l7zqj/tmp6y0ab_u8/pioinstaller.zip/pioinstaller/core.py", line 70, in install_platformio_core
  File "/tmp/.piocore-installer-dq7l7zqj/tmp6y0ab_u8/pioinstaller.zip/pioinstaller/core.py", line 98, in _install_platformio_core
  File "/tmp/.piocore-installer-dq7l7zqj/tmp6y0ab_u8/pioinstaller.zip/pioinstaller/penv.py", line 58, in create_core_penv
  File "/tmp/.piocore-installer-dq7l7zqj/tmp6y0ab_u8/pioinstaller.zip/pioinstaller/python.py", line 70, in fetch_portable_python
  File "/tmp/.piocore-installer-dq7l7zqj/tmp6y0ab_u8/pioinstaller.zip/pioinstaller/python.py", line 97, in get_portable_python_url
  File "/tmp/.piocore-installer-dq7l7zqj/tmp6y0ab_u8/pioinstaller.zip/requests/api.py", line 75, in get
  File "/tmp/.piocore-installer-dq7l7zqj/tmp6y0ab_u8/pioinstaller.zip/requests/api.py", line 61, in request
  File "/tmp/.piocore-installer-dq7l7zqj/tmp6y0ab_u8/pioinstaller.zip/requests/sessions.py", line 529, in request
  File "/tmp/.piocore-installer-dq7l7zqj/tmp6y0ab_u8/pioinstaller.zip/requests/sessions.py", line 645, in send
  File "/tmp/.piocore-installer-dq7l7zqj/tmp6y0ab_u8/pioinstaller.zip/requests/adapters.py", line 517, in send
requests.exceptions.SSLError: HTTPSConnectionPool(host='api.registry.platformio.org', port=443): Max retries exceeded with url: /v3/packages/platformio/tool/python-portable (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:997)')))
  File "<string>", line 105, in <module>
  File "<string>", line 101, in main
  File "/usr/lib/python3.10/subprocess.py", line 369, in check_call
    raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command '['/usr/bin/python3', '/tmp/tmpac9qs_43']' returned non-zero exit status 1.
Small precision :
On CentOS I’m running VSCode 1.52 (latest supported version on CentOS 7)
On Ubuntu I run VSCode 1.71 (latest version available)
Ok… I think I found the problem…
I guess corporate proxy configuration has changed and that *.https://registry.platformio.org/ are no more in the white list of the proxy:
I guess that certificates shown in previous picture are not correct in order to access platformio.org URLs
Regards,
José
Sites *.platformio.org have been added to proxy white list, but this does not solve my installing issue.
I still get this message during platformio core installation
Error: /home/cnes/marcosjl/.platformio/.cache/tmp/.piocore-installer-tcyvug4p/tmpexux44z8/pioinstaller.zip/urllib3/connectionpool.py:1043: InsecureRequestWarning: Unverified HTTPS request is being made to host 'localhost'. Adding certificate verification is strongly advised. See: https://urllib3.readthedocs.io/en/1.26.x/advanced-usage.html#ssl-warnings /home/cnes/marcosjl/.platformio/.cache/tmp/.piocore-installer-tcyvug4p/tmpexux44z8/pioinstaller.zip/urllib3/connectionpool.py:1043: InsecureRequestWarning: Unverified HTTPS request is being made to host 'localhost'. Adding certificate verification is strongly advised. See: https://urllib3.readthedocs.io/en/1.26.x/advanced-usage.html#ssl-warnin...
Hello again,
I’m puzzled !
I’ve managed to install PlatformIO IDE on a corporate Windows machine using the exact same configuration as the one I’m trying to use on Ubuntu 22.04 :
  • VS Code : 1.71
  • Local CNTLM proxy running in background
  • HTTP_PROXY and HTTPS_PROXY variables defined for my Windows account and pointing to CNTLM port.
  • VS Code settings to disable proxyStrictSSL
So to me it’s a problem of certificates not correctly configured in Ubuntu : I droped the AC *.crt files under /usr/local/share/ca_certificates and ran update-ca-certificates command.
But that’s not just enough…
Regards
Jose
But if those are “system certifcates”, wouldn’t you want to set
to true?
Setting http.systemCertificates to true does not change the installation error.
Ok.
I found a work around to my problem…
Following information provided here : https://stackoverflow.com/questions/36506539/how-do-i-get-visual-studio-code-to-trust-our-self-signed-proxy-certificate I managed to add my corporate AC certificates and thus have Visual Studio Code access properly to Internet through our corporate proxy.
This thread can be closed.
