Trying to initialize a new project with RPI (zero or rev 2 / B) on my windows 10 machine. Worked fine on OSX. Error message: Error: Could not find a version that satisfies the requirement ‘~1.40802.0’ for your system 'windows_amd64’
Any ideas?
Im having exactly the same problem on Linux trying to initialize RPi1 project:
Error: Could not find a version that satisfies the requirement '~1.40802.0' for your system 'linux_x86_64'
This is in IDE. What I’m getting in CLI is much more descriptive:
$ pio init -d rpi1_test -b raspberrypi_1b --ide atom
The next files/directories have been created in /home/jazg/work/rpi1_test
src - Put your source files here
Error: [Fri Feb 10 16:53:04 2017] Processing raspberrypi_1b (platform: linux_arm, board: raspberrypi_1b, framework: wiringpi)
Error: PlatformIO temporary does not support cross-compilation for WiringPi framework. Please run PlatformIO directly on Raspberry Pi
