I bought the P-NUCLEO-IHM03 development kit and wish to use vscode and PlatformIO to build and flash. I followed the official instruction to generate the motor control code by STM32CubeMX (Src, Inc, etc), and tried to build (compile) the project with PlatformIO but failed.
The error is:
Archiving .pio\build\nucleo_g431rb\libFrameworkCMSISDevice.a
Linking .pio\build\nucleo_g431rb\firmware.elf
.pio\build\nucleo_g431rb\libFrameworkCMSISDevice.a(startup_stm32g431xx.o): In functionLoopFillZerobss': (.text.Reset_Handler+0x32): undefined reference tomain’
*** [.pio\build\nucleo_g431rb\firmware.elf] Error 1
Does anyone have a clue on how to solve this issue? Please let me know if you need more info to identify the problem. I appreciate your discussion and help!
More info about the kit:
Control board: STM32 Nucleo G431RB
Power board: X-NUCLEO-IHM16M1
My working environment is windows 11.
Here is the main.c file generated by CubeMX:
/* USER CODE BEGIN Header */
* @file : main.c
* @brief : Main program body
* @attention
* Copyright (c) 2024 STMicroelectronics.
* All rights reserved.
* This software is licensed under terms that can be found in the LICENSE file
* in the root directory of this software component.
* If no LICENSE file comes with this software, it is provided AS-IS.
/* USER CODE END Header */
/* Includes ------------------------------------------------------------------*/
#include "main.h"
#include "adc.h"
#include "cordic.h"
#include "dma.h"
#include "tim.h"
#include "usart.h"
#include "gpio.h"
/* Private includes ----------------------------------------------------------*/
/* USER CODE BEGIN Includes */
/* USER CODE END Includes */
/* Private typedef -----------------------------------------------------------*/
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* Private define ------------------------------------------------------------*/
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PM */
/* USER CODE END PM */
/* Private variables ---------------------------------------------------------*/
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
static void MX_NVIC_Init(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
* @brief The application entry point.
* @retval int
int main(void)
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
/* MCU Configuration--------------------------------------------------------*/
/* Reset of all peripherals, Initializes the Flash interface and the Systick. */
HAL_Init();
/* USER CODE BEGIN Init */
/* USER CODE END Init */
/* Configure the system clock */
SystemClock_Config();
/* USER CODE BEGIN SysInit */
/* USER CODE END SysInit */
/* Initialize all configured peripherals */
MX_GPIO_Init();
MX_DMA_Init();
MX_ADC1_Init();
MX_ADC2_Init();
MX_CORDIC_Init();
MX_TIM1_Init();
MX_USART2_UART_Init();
MX_MotorControl_Init();
/* Initialize interrupts */
MX_NVIC_Init();
/* USER CODE BEGIN 2 */
/* USER CODE END 2 */
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1)
/* USER CODE END WHILE */
/* USER CODE BEGIN 3 */
/* USER CODE END 3 */
* @brief System Clock Configuration
* @retval None
RCC_OscInitTypeDef RCC_OscInitStruct = {0};
RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
/** Configure the main internal regulator output voltage
HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE1_BOOST);
/** Initializes the RCC Oscillators according to the specified parameters
* in the RCC_OscInitTypeDef structure.
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
RCC_OscInitStruct.HSEState = RCC_HSE_ON;
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
RCC_OscInitStruct.PLL.PLLM = RCC_PLLM_DIV6;
RCC_OscInitStruct.PLL.PLLN = 85;
RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV8;
RCC_OscInitStruct.PLL.PLLQ = RCC_PLLQ_DIV2;
RCC_OscInitStruct.PLL.PLLR = RCC_PLLR_DIV2;
if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
Error_Handler();
/** Initializes the CPU, AHB and APB buses clocks
RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
|RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_4) != HAL_OK)
Error_Handler();
/** Enables the Clock Security System
HAL_RCC_EnableCSS();
* @brief NVIC Configuration.
* @retval None
/* USART2_IRQn interrupt configuration */
HAL_NVIC_SetPriority(USART2_IRQn, 3, 1);
HAL_NVIC_EnableIRQ(USART2_IRQn);
/* DMA1_Channel1_IRQn interrupt configuration */
HAL_NVIC_SetPriority(DMA1_Channel1_IRQn, 3, 0);
HAL_NVIC_EnableIRQ(DMA1_Channel1_IRQn);
/* TIM1_BRK_TIM15_IRQn interrupt configuration */
HAL_NVIC_SetPriority(TIM1_BRK_TIM15_IRQn, 4, 1);
HAL_NVIC_EnableIRQ(TIM1_BRK_TIM15_IRQn);
/* TIM1_UP_TIM16_IRQn interrupt configuration */
HAL_NVIC_SetPriority(TIM1_UP_TIM16_IRQn, 0, 0);
HAL_NVIC_EnableIRQ(TIM1_UP_TIM16_IRQn);
/* ADC1_2_IRQn interrupt configuration */
HAL_NVIC_SetPriority(ADC1_2_IRQn, 2, 0);
HAL_NVIC_EnableIRQ(ADC1_2_IRQn);
/* EXTI15_10_IRQn interrupt configuration */
HAL_NVIC_SetPriority(EXTI15_10_IRQn, 3, 0);
HAL_NVIC_EnableIRQ(EXTI15_10_IRQn);
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
* @brief This function is executed in case of error occurrence.
* @retval None
void Error_Handler(void)
/* USER CODE BEGIN Error_Handler_Debug */
/* User can add his own implementation to report the HAL error return state */
__disable_irq();
while (1)
/* USER CODE END Error_Handler_Debug */
#ifdef USE_FULL_ASSERT
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @param file: pointer to the source file name
* @param line: assert_param error line source number
* @retval None
void assert_failed(uint8_t *file, uint32_t line)
/* USER CODE BEGIN 6 */
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
Not sure if you need the full log so I paste it here:
Processing nucleo_g431rb (platform: ststm32; board: nucleo_g431rb; framework: stm32cube)
Verbose mode can be enabled via-v, --verboseoption
CONFIGURATION:
https://docs.platformio.org/page/boards/ststm32/nucleo_g431rb.htmlPLATFORM: ST STM32 (17.3.0) > Nucleo G431RB
HARDWARE: STM32G431RBT6 170MHz, 32KB RAM, 128KB Flash
- framework-stm32cubeg4 @ 1.4.0
- tool-ldscripts-ststm32 @ 0.2.0
- toolchain-gccarmnoneeabi @ 1.70201.0 (7.2.1)
LDF: Library Dependency Finder →https://bit.ly/configure-pio-ldf
Found 23 compatible libraries
Scanning dependencies…
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_adc.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_adc_ex.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_comp.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_cordic.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_cortex.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_crc.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_crc_ex.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_cryp.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_cryp_ex.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_dac.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_dac_ex.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_dma.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_dma_ex.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_exti.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_fdcan.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_flash.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_flash_ex.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_flash_ramfunc.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_fmac.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_gpio.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_hrtim.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_i2c.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_i2c_ex.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_i2s.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_irda.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_iwdg.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_lptim.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_nand.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_nor.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_opamp.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_opamp_ex.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_pcd.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_pcd_ex.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_pwr.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_pwr_ex.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_qspi.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_rcc.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_rcc_ex.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_rng.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_rtc.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_rtc_ex.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_sai.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_sai_ex.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_smartcard.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_smartcard_ex.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_smbus.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_smbus_ex.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_spi.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_spi_ex.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_sram.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_tim.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_tim_ex.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_uart.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_uart_ex.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_usart.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_usart_ex.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_hal_wwdg.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_ll_adc.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_ll_comp.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_ll_cordic.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_ll_crc.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_ll_crs.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_ll_dac.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_ll_dma.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_ll_exti.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_ll_fmac.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_ll_fmc.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_ll_gpio.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_ll_hrtim.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_ll_i2c.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_ll_lptim.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_ll_lpuart.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_ll_opamp.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_ll_pwr.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_ll_rcc.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_ll_rng.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_ll_rtc.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_ll_spi.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_ll_tim.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_ll_ucpd.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_ll_usart.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_ll_usb.o
Compiling .pio\build\nucleo_g431rb\FrameworkHALDriver\Src\stm32g4xx_ll_utils.o
Compiling .pio\build\nucleo_g431rb\FrameworkCMSISDevice\gcc\startup_stm32g431xx.o
Compiling .pio\build\nucleo_g431rb\FrameworkCMSISDevice\system_stm32g4xx.o
