I am compiling the DEMO for Marlin-bugfix-2.0.x BTT_GTR_V1.0-Demo unmodified. Started with iMAC with Xcode and installed VSCODE then the PIO addon. The error look like file access or linking errors.
this is just the tail end:
/Users/bkauf/.platformio/packages/framework-arduinoststm32/system/Drivers/STM32F4xx_HAL_Driver/Inc/stm32f4xx_ll_tim.h: In function ‘void LL_TIM_EnableBRK(TIM_TypeDef*)’:
/Users/bkauf/.platformio/packages/framework-arduinoststm32/system/Drivers/STM32F4xx_HAL_Driver/Inc/stm32f4xx_ll_tim.h:2797:10: warning: conversion to void will not access object of type ‘volatile uint32_t {aka volatile long unsigned int}’
(void)(tmpreg);
/Users/bkauf/.platformio/packages/framework-arduinoststm32/system/Drivers/STM32F4xx_HAL_Driver/Inc/stm32f4xx_ll_tim.h: In function ‘void LL_TIM_DisableBRK(TIM_TypeDef*)’:
/Users/bkauf/.platformio/packages/framework-arduinoststm32/system/Drivers/STM32F4xx_HAL_Driver/Inc/stm32f4xx_ll_tim.h:2814:10: warning: conversion to void will not access object of type ‘volatile uint32_t {aka volatile long unsigned int}’
(void)(tmpreg);
/Users/bkauf/.platformio/packages/framework-arduinoststm32/system/Drivers/STM32F4xx_HAL_Driver/Inc/stm32f4xx_ll_tim.h: In function ‘void LL_TIM_ConfigBRK(TIM_TypeDef*, uint32_t)’:
/Users/bkauf/.platformio/packages/framework-arduinoststm32/system/Drivers/STM32F4xx_HAL_Driver/Inc/stm32f4xx_ll_tim.h:2834:10: warning: conversion to void will not access object of type ‘volatile uint32_t {aka volatile long unsigned int}’
(void)(tmpreg);
/Users/bkauf/.platformio/packages/toolchain-gccarmnoneeabi/bin/…/lib/gcc/arm-none-eabi/7.2.1/…/…/…/…/arm-none-eabi/bin/ld: cannot open linker script file stm32f407xg.ld: No such file or directory
*** [.pio/build/BIGTREE_GTR_V1_0/firmware.elf] Error 1
I have even added ~/.platformio to my path: "Bretts-iMac-2:~ bkauf$ echo $PATH
~/.platformio:/Library/Frameworks/Python.framework/Versions/3.8/bin:/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin
Bretts-iMac-2:~ bkauf$ "
python --version: Python 2.7.16
pip --version: pip 20.0.2 from /Library/Python/2.7/site-packages/pip-20.0.2-py2.7.egg/pip (python 2.7)
but
inputing pio home: -bash: pio: command not found
echo $PATH:
- Do you have to have .pio for each folder in the path?
- This used to work for two other printers with different boards on Marlin 2.0.x
- When I give the config.h, configadv.h and pins file to someone with a PC, it compiles fine.
- My guess (and I’m happy to be wrong) is that there is something wrong with the Mac installer.
Can someone help me move forward please?
