It seems like I’m doing something wrong, on platformio.ini
I have:
[env:esp32]
platform = espressif32@3.5.0 # IDF 4.3.2
board = pico32
Confirmed when building:
Processing esp32 (platform: espressif32@3.5.0; board: pico32; framework: arduino)
-------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/pico32.html
PLATFORM: Espressif 32 (3.5.0) > ESP32 Pico Kit
- framework-arduinoespressif32 3.10006.210326 (1.0.6)
- tool-esptoolpy 1.30100.210531 (3.1.0)
- tool-openocd-esp32 2.1000.20210721 (10.0)
- toolchain-xtensa32 2.50200.97 (5.2.0)
Found 32 compatible libraries
When I call for esp_get_idf_version()
the result is v3.3.5-1-g85c43024c
and I would expect v4.3.2
I have tried:
- Delete
.pio
directory; - Delete
.vscode
directory; - Delete
.platformio/framework-arduinoespressif32
directory; - Delete
.platformio/platforms/espressif32
directory; - Using a different version
platform = espressif32@3.4.0
- Remove Platform from PlatformIO Home;
The result is always the same esp_get_idf_version()
= v3.3.5-1-g85c43024c
… I’m afraid it is cached somewhere, where?
