Brand new Wemos D1 mini Pro, macOS 12.2 on Apple Silicon, plus a user new to this kind of development.
Trying to flash with the sample Blink project, fails with the error:
A fatal error occurred: Failed to write to target RAM (result was 0107)
full output:
> Executing task: platformio run --target upload <
Processing d1_mini_pro (platform: espressif8266; board: d1_mini_pro; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/d1_mini_pro.html
PLATFORM: Espressif 8266 (3.2.0) > WeMos D1 mini Pro
HARDWARE: ESP8266 80MHz, 80KB RAM, 16MB Flash
- framework-arduinoespressif8266 3.30002.0 (3.0.2)
- tool-esptool 1.413.0 (4.13)
- tool-esptoolpy 1.30000.201119 (3.0.0)
- tool-mklittlefs 1.203.210628 (2.3)
- tool-mkspiffs 1.200.0 (2.0)
- toolchain-xtensa 2.100300.210717 (10.3.0)
Found 35 compatible libraries
Retrieving maximum program size .pio/build/d1_mini_pro/firmware.elf
Checking size .pio/build/d1_mini_pro/firmware.elf
RAM: [=== ] 34.2% (used 27980 bytes from 81920 bytes)
Flash: [== ] 25.0% (used 260893 bytes from 1044464 bytes)
AVAILABLE: espota, esptool
Looking for upload port...
Auto-detected: /dev/cu.usbmodem52D20156021
Uploading .pio/build/d1_mini_pro/firmware.bin
esptool.py v3.0
Serial port /dev/cu.usbmodem52D20156021
Connecting....
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
MAC: 5c:cf:7f:86:7d:90
Uploading stub...
*** [upload] Error 2
=========================================================== [FAILED] Took 1.41 seconds ===========================================================
The terminal process "platformio 'run', '--target', 'upload'" terminated with exit code: 1.
platform.ini
[env:d1_mini_pro]
platform = espressif8266
board = d1_mini_pro
build_flags = -D LED_BUILTIN=RED_LED
board_build.flash_mode = dio
upload_speed = 115200
upload_resetmethod = nodemcu
Connecting from MacBook Pro USB-C ports to microUSB on the board. USB cables are data cables, not charge cables, so have eliminated that possible mistake.
I’ve tried various combinations of upload_speed, upload_resetmethod, board_build.flash_mode, 3 different USB cables & USB-C to USB-A adaptors, and 2 different brand new Wemos D1 mini Pro boards.
Setting upload_resetmethod = ck
gives
Connecting........_____....._____....._____....._____....._____....._____....._____
A fatal error occurred: Failed to connect to ESP8266: Timed out waiting for packet header
Solutions for similar flashing problems like passing --before no_reset
( Suddenly cannot flash NodeMCU ESP8266 ) won’t work for me, the board only has a reset button, no flash button.
Has anyone got these boards working from macOS?
