Thanks, @pfeerick. How would I go about doing that? I’m in VS Code. Open a terminal, run pip install pyyaml
- it says the package is already installed. Then I run pio run
and I get
ModuleNotFoundError: No module named 'pyyaml':
File "/Users/frank/.platformio/penv/lib/python3.6/site-packages/platformio/builder/main.py", line 126:
File "/Users/frank/.platformio/packages/tool-scons/script/../engine/SCons/Script/SConscript.py", line 605:
File "/Users/frank/.platformio/packages/tool-scons/script/../engine/SCons/Script/SConscript.py", line 286:
File "/Users/frank/.platformio/platforms/atmelsam/builder/main.py", line 120:
File "/Users/frank/.platformio/packages/tool-scons/script/../engine/SCons/Environment.py", line 224:
File "/Users/frank/.platformio/penv/lib/python3.6/site-packages/platformio/builder/tools/platformio.py", line 122:
_build_project_deps(env)
File "/Users/frank/.platformio/penv/lib/python3.6/site-packages/platformio/builder/tools/platformio.py", line 47:
project_lib_builder = env.ConfigureProjectLibBuilder()
File "/Users/frank/.platformio/penv/lib/python3.6/site-packages/platformio/builder/tools/piolib.py", line 1043:
project.install_dependencies()
File "/Users/frank/.platformio/penv/lib/python3.6/site-packages/platformio/builder/tools/piolib.py", line 861:
if _is_builtin(uri):
File "/Users/frank/.platformio/penv/lib/python3.6/site-packages/platformio/builder/tools/piolib.py", line 853:
for lb in self.env.GetLibBuilders():
File "/Users/frank/.platformio/penv/lib/python3.6/site-packages/platformio/builder/tools/piolib.py", line 973:
lb = LibBuilderFactory.new(env, lib_dir)
File "/Users/frank/.platformio/penv/lib/python3.6/site-packages/platformio/builder/tools/piolib.py", line 59:
verbose=verbose)
File "/Users/frank/.platformio/penv/lib/python3.6/site-packages/platformio/builder/tools/piolib.py", line 130:
self.process_extra_options()
File "/Users/frank/.platformio/penv/lib/python3.6/site-packages/platformio/builder/tools/piolib.py", line 269:
"pio_lib_builder": self
File "/Users/frank/Futurose/Arduino/FreeRTOS/lib/AtmelStartASF4/library.py", line 3:
import pyyaml
That makes me think I need to activate the venv with something like python -m venv /Users/frank/.platformio/penv
, but after doing that and install and run, I get the same module not found. There’s no activate
in the .platformio directory. How do I go about activating the virtualenv that PlatformIO uses?
