elral
December 31, 2023, 8:14am
1
Is there a way to run a script after all environments are compiled?
I am having really problems to firgure out what arguments can be passed to env.AddPostAction([argument], copy_fw_files) and even I am not sure if this would be the correct way via extra_scripts.
And what would be the argument if I want to copy an .uf2 file instead of a .hex file after compiling for a Raspberry Pico? .uf2 as argument does not work.
→ edit: for now I am checking for .bin and if so substituting by .uf2 before copying.
elral
December 31, 2023, 2:20pm
3
Hmhm, not sure.
We have a platformio.ini file like:
; Build settings for the Arduino Mega
[env:mobiflight_mega]
board = megaatmega2560
${env.build_flags}
-I./_Boards/Atmel/Board_Mega
build_src_filter =
${env.build_src_filter}
${env.lib_deps}
${env.custom_lib_deps_Atmel}
extra_scripts =
${env.extra_scripts}
; Build settings for the Arduino Pro Micro
[env:mobiflight_micro]
board = sparkfun_promicro16
${env.build_flags}
-I./_Boards/Atmel/Board_ProMicro
build_src_filter =
${env.lib_deps}
extra_scripts =
; Build settings for the Arduino Uno
[env:mobiflight_uno]
board = uno
${env.build_flags}
-I./_Boards/Atmel/Board_Uno
build_src_filter =
${env.lib_deps}
extra_scripts =
; Build settings for the Arduino Nano
[env:mobiflight_nano]
board = nanoatmega328
${env.build_flags}
-I./_Boards/Atmel/Board_Nano
build_src_filter =
${env.lib_deps}
extra_scripts =
; Build settings for the Raspberry Pico original
[env:mobiflight_raspberrypico]
platform = https://github.com/maxgerhardt/platform-raspberrypi.git
board = pico
board_build.core = earlephilhower ; select new core
board_build.filesystem_size = 0M ; configure filesystem size. Default 0 Mbyte.
lib_ldf_mode = chain+
upload_protocol = mbed ; for debugging upoading can be changed to picoprobe
;debug_tool = picoprobe ; and uncomment this for debugging w/ picoprobe
${env.build_flags}
-I./_Boards/RaspberryPi/Pico
build_src_filter =
${env.lib_deps}
ricaun/ArduinoUniqueID @ ^1.3.0
extra_scripts =
There is already one extra_script which gets exectuted for each environment.
But now we need to run a script after all environments were build, so when pio run is finished.
We don’t provide this option. You can wrap the pio run command with some external script (Bash, Python, etc) and later process your custom commands/logic.
