Hello!
I have attached two pre:extra_scripts. However, I have noticed, they are run 1 two 5 times for each “build” and also for “minor” actions, like building the filesystem buildfs
or even just checking size.
My question would be, is there a way to limit execution of extra_scripts to just ONE time? Reason: I use it to generate some hashes and version numbers. And, more importantly, set PROGNAME + ESP8266_FS_IMAGE_NAME.
I have read into the topic of targets and can check, which targets are “run” (via BUILD_TARGETS python object). However, for a “plain build” run, this object is empty and the script is nevertheless called a few time, which of course is undesired, as hash values change between runs and firmware image is generated not in the last run.
Any idea, where to start?
