#include "functions.h"
int foo(int 1, in 2);
int foo(int 1, int2, int 3);
functions.h
#ifndef FUNCTIONS_H
#define FUNCTIONS_H
//versin 1
void foo(int a, int b, int c);
//version 2
void foo(int a, int b, int c=0);
functions.cpp
int x:
x = a+b+c;
but I get errors
with version 1 in the header file I get too may arguments in main.cpp
with version 2 in the header file I get default argument given for parameter 3 of void 'foo(… in functios.cpp
after previous specification in void 'foo(…
in functions.h
What is supposed to do? Declare the function? Call it? This is not valid C/C++ syntax.
Both of these function declarations are okay on their own, but default parameters are only allowed in the declaration, not in the definition. So in the functions.cpp,
the int c=0 is invalid, that must be int c.
Also, in relation to the first question:
it looks like you declare foo to be of return value type int, but the implementation and other header file declares it as void. The result of a+b+c is stored in a global variable x and not given as the return value – are you sure that that’s what you want?
Thanks for quick response. Sorry I did a mistype there is no return parameter so it should be foo(1, 2); and food(1, 2, 3);
in the first line the default parameter value = 0 should be used in the second the passed parameter value 3.
I omittdet the =0 ind the header and have it only in the cpp file. But I get the error too few arguments in main.cpp
I posted here just an example, the problem is i a project with over a 1000 lines of code and this is the last compile error. I will create an extract with the problem, give me a bit of time
test(1, 2);
test(1,2,3);
[/code]
func.h
#ifndef FUNC_H
#define FUNC_H
void test(int a, int b, int c);
func.cpp
#include "func.h"
int x;
void test(int a, int b, int c=0)
x= a+b+c;
Error message
src/main.cpp: In function ‘void loop()’:
src/main.cpp:10:12: error: too few arguments to function ‘void test(int, int, int)’
test(1, 2);
In file included from src/main.cpp:2:0:
src/func.h:4:6: note: declared here
*** [.pio/build/esp12e/src/main.cpp.o] Error 1
The function declaration in the header must have the default parameter int c=0, the function implementation in the cpp file must not have that, aka it must use int c.
