I’m pretty fresh to zephyr and device tress. I’ve encountered it a bit at work but haven’t quite become friends with it.
I’ve taken a simple blinky example which works fine. The LED blinks and now I’m just trying to add another LED for me to control. I thought this would be a simple copy paste with minor modifications but I’m missing something fundamental here.
I’m trying to keep this minimal
This is my dts file
* Copyright (c) 2017 Arthur Sfez
* Based on stm32L476g_disco:
* Copyright (c) 2017 Linaro Limited
* SPDX-License-Identifier: Apache-2.0
/dts-v1/;
#include <st/l4/stm32l431Xc.dtsi>
#include <st/l4/stm32l431r(b-c)yx-pinctrl.dtsi>
model = "Custom STM32L431RC board";
compatible = "st,devboard";
chosen {
zephyr,console = &usart2;
zephyr,shell-uart = &usart2;
zephyr,sram = &sram0;
zephyr,flash = &flash0;
leds {
compatible = "gpio-leds";
green_0: led_0 {
gpios = <&gpioc 2 GPIO_ACTIVE_HIGH>;
green_1: led_1 {
gpios = <&gpioc 3 GPIO_ACTIVE_HIGH>;
aliases {
led0 = &green_0;
led1 = &green_1;
&clk_lsi {
status = "okay";
&clk_hsi {
status = "okay";
&pll {
div-m = <2>;
mul-n = <20>;
div-p = <7>;
div-q = <8>;
div-r = <2>;
clocks = <&clk_hsi>;
status = "okay";
&rcc {
clocks = <&pll>;
clock-frequency = <DT_FREQ_M(80)>;
ahb-prescaler = <1>;
apb1-prescaler = <1>;
apb2-prescaler = <1>;
&usart2 {
pinctrl-0 = <&usart3_tx_pc10 &usart3_rx_pc11>;
pinctrl-names = "default";
current-speed = <921600>;
status = "okay";
&rtc {
clocks = <&rcc STM32_CLOCK_BUS_APB1 0x10000000>,
<&rcc STM32_SRC_LSI RTC_SEL(2)>;
status = "okay";
backup_regs {
status = "okay";
And here is my main where I try to use it
#include <zephyr/kernel.h>
#include <zephyr/drivers/gpio.h>
/* 1000 msec = 1 sec */
#define SLEEP_TIME_MS 300
/* The devicetree node identifier for the "led0" alias. */
#define LED0_NODE DT_ALIAS(led0)
#define LED1_NODE DT_ALIAS(led1)
static const struct gpio_dt_spec led0 = GPIO_DT_SPEC_GET(LED0_NODE, gpios);
static const struct gpio_dt_spec led1 = GPIO_DT_SPEC_GET(LED1_NODE, gpios);
int main() {
if (!gpio_is_ready_dt(&led0))
return 1;
int ret = gpio_pin_configure_dt(&led0, GPIO_OUTPUT_ACTIVE);
if (ret < 0)
return 1;
while (1)
ret = gpio_pin_toggle_dt(&led0);
if (ret < 0)
return 1;
k_msleep(SLEEP_TIME_MS);
I’m not using led1 yet because it’s already failing at the GPIO_DT_SPEC_GET macro with the following error.
Compiling .pio/build/stm32l431rc/src/main.o
In file included from /home/simon/.platformio/packages/framework-zephyr/include/zephyr/toolchain/gcc.h:92,
from /home/simon/.platformio/packages/framework-zephyr/include/zephyr/toolchain.h:50,
from /home/simon/.platformio/packages/framework-zephyr/include/zephyr/kernel_includes.h:19,
from /home/simon/.platformio/packages/framework-zephyr/include/zephyr/kernel.h:17,
from src/main.cpp:2:
/home/simon/.platformio/packages/framework-zephyr/include/zephyr/device.h:85:41: error: ‘__device_dts_ord_DT_N_ALIAS_led1_P_gpios_IDX_0_PH_ORD’ was not declared in this scope
85 | #define DEVICE_NAME_GET(dev_id) _CONCAT(_device, dev_id)
/home/simon/.platformio/packages/framework-zephyr/include/zephyr/toolchain/common.h:132:26: note: in definition of macro ‘_DO_CONCAT’
132 | #define _DO_CONCAT(x, y) x ## y
/home/simon/.platformio/packages/framework-zephyr/include/zephyr/device.h:85:33: note: in expansion of macro ‘_CONCAT’
85 | #define DEVICE_NAME_GET(dev_id) CONCAT(device, dev_id)
/home/simon/.platformio/packages/framework-zephyr/include/zephyr/device.h:211:37: note: in expansion of macro ‘DEVICE_NAME_GET’
211 | #define DEVICE_DT_NAME_GET(node_id) DEVICE_NAME_GET(Z_DEVICE_DT_DEV_ID(node_id))
/home/simon/.platformio/packages/framework-zephyr/include/zephyr/device.h:228:34: note: in expansion of macro ‘DEVICE_DT_NAME_GET’
228 | #define DEVICE_DT_GET(node_id) (&DEVICE_DT_NAME_GET(node_id))
/home/simon/.platformio/packages/framework-zephyr/include/zephyr/drivers/gpio.h:331:25: note: in expansion of macro ‘DEVICE_DT_GET’
331 | .port = DEVICE_DT_GET(DT_GPIO_CTLR_BY_IDX(node_id, prop, idx)),
/home/simon/.platformio/packages/framework-zephyr/include/zephyr/drivers/gpio.h:367:9: note: in expansion of macro ‘GPIO_DT_SPEC_GET_BY_IDX’
367 | GPIO_DT_SPEC_GET_BY_IDX(node_id, prop, 0)
src/main.cpp:13:41: note: in expansion of macro ‘GPIO_DT_SPEC_GET’
13 | static const struct gpio_dt_spec led1 = GPIO_DT_SPEC_GET(LED1_NODE, gpios);
In file included from /home/simon/.platformio/packages/framework-zephyr/include/zephyr/arch/arm/aarch32/arch.h:20,
from /home/simon/.platformio/packages/framework-zephyr/include/zephyr/arch/cpu.h:19,
from /home/simon/.platformio/packages/framework-zephyr/include/zephyr/kernel_includes.h:33:
/home/simon/.platformio/packages/framework-zephyr/include/zephyr/devicetree.h:233:32: error: ‘DT_N_ALIAS_led1_P_gpios_IDX_0_VAL_pin’ was not declared in this scope; did you mean ‘DT_N_S_leds_S_led_0_P_gpios_IDX_0_VAL_pin’?
233 | #define DT_ALIAS(alias) DT_CAT(DT_N_ALIAS, alias)
/home/simon/.platformio/packages/framework-zephyr/include/zephyr/devicetree.h:4151:9: note: in definition of macro ‘DT_CAT7’
4151 | a1 ## a2 ## a3 ## a4 ## a5 ## a6 ## a7
/home/simon/.platformio/packages/framework-zephyr/include/zephyr/devicetree/gpio.h:164:9: note: in expansion of macro ‘DT_PHA_BY_IDX’
164 | DT_PHA_BY_IDX(node_id, gpio_pha, idx, pin)
/home/simon/.platformio/packages/framework-zephyr/include/zephyr/drivers/gpio.h:332:24: note: in expansion of macro ‘DT_GPIO_PIN_BY_IDX’
332 | .pin = DT_GPIO_PIN_BY_IDX(node_id, prop, idx),
/home/simon/.platformio/packages/framework-zephyr/include/zephyr/devicetree.h:233:25: note: in expansion of macro ‘DT_CAT’
src/main.cpp:10:19: note: in expansion of macro ‘DT_ALIAS’
10 | #define LED1_NODE DT_ALIAS(led1)
src/main.cpp:13:58: note: in expansion of macro ‘LED1_NODE’
src/main.cpp:13:34: warning: ‘led1’ defined but not used [-Wunused-variable]
*** [.pio/build/stm32l431rc/src/main.o] Error 1
I can’t see why led0 would work but not led1.
I appreciate your help.
EDIT:
I found someone having a similar problem on the Nordic Semi forum:
They don’t seem to be able to give a straight simple answer. Is it really this difficult to do something so basic?
