htmlll
1
I am new to platformIO, i am currently working on a LED strip project.
I have all my code written but when I go to compile I get the error
"expected primary-expression before '__attribute__'", in the .pio
This is what versions i am using
I don’t even know where to start with fixing it, I don’t know if its because of a library i have installed or what.
I am using an Arduino Uno if that helps
Us neither when we don’t see the code causing it
Please show the full platformio.ini and code for reproduction.
htmlll
3
Hopefully this helps let me know
htmlll
4
This is a error happening in the .pio
This issue has already been discussed at Fastled clockless_trinket.h:326:24: error - #6 by maxgerhardt. You need to use a newer compiler version to use this library. Adding
platform_packages =
; use GCC AVR 7.3.0+
toolchain-atmelavr@>=1.70300.0
to the platformio.ini fixes it.
