Is there some way to exclude specific source code files located inside an internal library?
I tried to add a library.json with a exclude directive inside the internal library directory but without success.
Regards,
Regards,
If you talk about a local library, then we have an issue for that #289.
If you are going to add library to PlatformIO Registry, you can use exclude field from library.json.
I see it’s implemented now. Is there also a possibility to define the src_filter for the local library in platformio.ini instead of library.json, because I need an exclude just for a specific environment…
EDIT: I found this meanwhile, will give it a try.
