I normally use CLion, but tried this in the Arduino IDE too.
[env:seeed_xiao_esp32c3]
board = seeed_xiao_esp32c3
lib_deps = fastled/FastLED@^3.6.0
it doesn’t “know” or “care” what IDE compiled the code.
I’m thinking in terms of code that exists in the env as support. IOW, something calls loop(). The support code in the environment might be different if compiled by PlatformIO verses Arduino.
How do you know that it takes 130 ms to restart the loop? / debugger
Since the device spins I cannot plug into it. I tried to capture logs to be printed after a spin cycle, but the Arduino seems to reset when I connect it to my computer. In order to determine the time measurements I use an external LED and binary search a value. To determine loop time I captured micros() at the end of a loop() call and then took the difference between that and micros() at the beginning.
That is an extremely long duration…
Agreed.
My code
#include <FastLED.h>
#define LED_PIN_1 D0
#define LED_PIN_2 D1
#define HALL_SENSOR D10
#define LED_ON D4
const unsigned int NUM_LEDS = 30;
const unsigned int FRAME_COUNT = 3;
const unsigned long FRAME_RATE = 1000000; // 1 second
const CRGB BRIGHT_BLUE = 0x7799FF;
const CRGB BRIGHT_GREEN = 0x22FF00;
CRGB frames[FRAME_COUNT][NUM_LEDS][NUM_LEDS] = {
{ CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black },
{ CRGB::Red, CRGB::Red, CRGB::Red, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black },
{ CRGB::Red, CRGB::Red, CRGB::Red, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Red, CRGB::Red, CRGB::Black, CRGB::Black, CRGB::Black },
{ CRGB::Red, CRGB::Red, CRGB::Red, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Red, CRGB::Red, CRGB::Red, CRGB::Black, CRGB::Black },
{ CRGB::Red, CRGB::Red, CRGB::Red, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Red, CRGB::Red, CRGB::Red, CRGB::Red, CRGB::Black },
{ CRGB::Red, CRGB::Red, CRGB::Red, CRGB::Red, CRGB::Red, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Red, CRGB::Red, CRGB::Red, CRGB::Red, CRGB::Red },
{ CRGB::Red, CRGB::Red, CRGB::Red, CRGB::Red, CRGB::Red, CRGB::Red, CRGB::Red, CRGB::Red, CRGB::Red, CRGB::Red, CRGB::Red, CRGB::Red, CRGB::Red, CRGB::Red, CRGB::Red, CRGB::Red, CRGB::Red, CRGB::Red, CRGB::Red, CRGB::Red, CRGB::Red, CRGB::Red, CRGB::Red, CRGB::Red, CRGB::Red, CRGB::Red, CRGB::Red, CRGB::Red, CRGB::Red, CRGB::Red },
// omitted for brevity
// Angles are measured in units of 10000. 180 degrees is not enough resolution
const unsigned long ANGLE_ALL = 1440;
const unsigned long QUIET_START_ANGLE = 60;
const unsigned long COLUMN_ANGLE = 1;
const unsigned long ANTI_BOUNCE = 3000;
const unsigned long MAX_SPIN_DURATION = 5000000; // 2 seconds
unsigned long FREQ = 2000;
unsigned long times[4] = {};
enum ROTATION_STATE { IDLE = 1, SETUP = 2, QUIET_START = 3, GRID_1 = 4, QUIET_MIDDLE = 5, GRID_2 = 6, QUIET_END = 7 };
CRGB leds_1[NUM_LEDS];
CRGB leds_2[NUM_LEDS];
//BLECharacteristic *pCharacteristic;
ROTATION_STATE rotationState = IDLE;
volatile unsigned long spinStart = 0; // time of next event, usually a column
volatile unsigned long spinTime = 0; // duration of spin in microseconds
volatile bool bNewSpin = false; // how the Hall sensor communicates to the main loop that a new spin has started
volatile unsigned long nextEvent = 0; // time of next event, e.g. a column of pixels
unsigned int nColumn = 0; // column currently being drawn
volatile unsigned int nFrame = -1; // frame of the animation being drawn
volatile unsigned long nChangeFrameAt = 0;
volatile unsigned long maxWrite = 0;
void shine(CRGB color) {
for (int j=0; j<NUM_LEDS; j++) {
leds_1[j] = color;
// leds_2[j] = color;
FastLED.show();
void dark() {
leds_1[j] = CRGB::Black;
// leds_2[j] = CRGB::Black;
FastLED.show();
//Hall sensor 1 interrupt routine
void ISR_HallSensor() {
unsigned long now = micros();
// Check if HYS ms have passed since the last trigger
if (now - spinStart >= ANTI_BOUNCE) { // assume triggers within ANTI_BOUNCE are bounces
if (spinStart != 0) { // calculate spinTime only if we have a valid lastHallTrigger
spinTime = (now - spinStart);
bNewSpin = true;
spinStart = now;
// writes a column of pixels
void writeColumn(CRGB *frames) {
leds_1[j] = frames[j];
FastLED.show();
FastLED.addLeds<NEOPIXEL, LED_PIN_1>(leds_1, NUM_LEDS);
FastLED.addLeds<NEOPIXEL, LED_PIN_2>(leds_2, NUM_LEDS);
Serial.begin(250000);
pinMode(HALL_SENSOR, INPUT);
pinMode(LED_ON, OUTPUT);
attachInterrupt(digitalPinToInterrupt(HALL_SENSOR), ISR_HallSensor, RISING);
volatile int test1 = -1;
int duration = (test1 != -1) ? (int)micros() - test1 : 0;
if (duration > maxWrite) {
maxWrite = duration;
if (maxWrite > 131250) {
digitalWrite(LED_ON, HIGH);
if (bNewSpin) {
rotationState = SETUP;
bNewSpin = false;
if (now > nChangeFrameAt) {
nFrame = ++nFrame % FRAME_COUNT;
nChangeFrameAt = now + FRAME_RATE;
unsigned long progress = now - spinStart;
switch (rotationState) {
case IDLE: // just wait here for a new rotation
break;
case SETUP: // just wait here for a new rotation
nextEvent = progress + ((spinTime * QUIET_START_ANGLE) / ANGLE_ALL);
rotationState = QUIET_START;
break;
case QUIET_START:
if (progress > nextEvent) {
nColumn = 0;
rotationState = GRID_1;
break;
case GRID_1:
if (nColumn > NUM_LEDS) {
dark();
rotationState = QUIET_MIDDLE;
} else {
writeColumn(frames[nFrame][nColumn++]);
nextEvent = progress + ((spinTime * COLUMN_ANGLE) / ANGLE_ALL);
break;
case QUIET_MIDDLE:
break;
} // switch on rotationState
test1 = micros();
