Hi everyone.
At first I thought that I was missing something, but after a lot of investigations, I can’t find anything wrong. My latest library, BootInfo, has an example that’s not showing, see here.
Can someone point out what’s wrong?
Thanks a lot.
Hi everyone.
Thanks a lot.
The manifest isn’t showing either, but confusingly the PIO Registry knows where it lives, since when I hit the ‘edit’ button it opens up on GitLab. I noticed your NMEAParser library is in the same state. Nothing jumps out as being wrong though.
btw, Any chance you can add a screenshot of what something like SimpleTest looks like to the readme for that library? I was just looking at it, and it would be nice to get and idea of what the fuss is all about. i.e. Why would I want to use it? ![]()
@ivankravets Does the crawler need another prod? ![]()
You nailed it, my other lib is in the very same situation. Through a few tests I tried to sold the issue, but nothing worked. I’m starting to wonder if the issue is not related to Gitlab…
And yes, I will definitely put more into into the README. Meanwhile you can check the release page if you’re curious ![]()
Oh, very nice! I might borrow some of that for use with the ESP8266
I’m planning to port it to the ESP8266/12E very soon, and also to reduce the bond to the Arduino framework
The result is OK. You pointed library.json to downloadUrl that does not have examples in the root unpacked archive. The short answer:
downloadUrl
repository.url to https://gitlab.com/X99/bootinfo.git
PlatformIO will automatically d t he rest work for you.
Thank you @ivankravets
