I was working on my project and everything compiles well but suddenly the code not working anymore and produces numerous errors, at the first I thought I made the coding mistake but I have noticed even fresh empty code such as a following is not working anymore
these are errors that come up from compiling the above code
---------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
PLATFORM: Espressif 32 (3.5.0) > Espressif ESP32 Dev Module
- framework-arduinoespressif32 3.10006.210326 (1.0.6)
- tool-esptoolpy 1.30100.210531 (3.1.0)
- toolchain-xtensa32 2.50200.97 (5.2.0)
Found 28 compatible libraries
Compiling .pio\build\esp32dev\src\main.cpp.o
Generating partitions .pio\build\esp32dev\partitions.bin
Archiving .pio\build\esp32dev\libFrameworkArduinoVariant.a
Compiling .pio\build\esp32dev\FrameworkArduino\Esp.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\FunctionalInterrupt.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\HardwareSerial.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\IPAddress.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\IPv6Address.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\MD5Builder.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\Print.cpp.o
In file included from C:\Users\Hamid\.platformio\packages\framework-arduinoespressif32\cores\esp32\HardwareSerial.cpp:7:0:
C:\Users\Hamid\.platformio\packages\framework-arduinoespressif32\cores\esp32\HardwareSerial.h:54:1: error: expected class-name before '{' token
*** [.pio\build\esp32dev\FrameworkArduino\HardwareSerial.cpp.o] Error 1
In file included from C:\Users\Hamid\.platformio\packages\framework-arduinoespressif32\cores\esp32/Arduino.h:151:0,
from src\main.cpp:1:
C:\Users\Hamid\.platformio\packages\framework-arduinoespressif32\cores\esp32/Client.h:27:1: error: expected class-name before '{' token
In file included from C:\Users\Hamid\.platformio\packages\framework-arduinoespressif32\cores\esp32/Arduino.h:153:0,
C:\Users\Hamid\.platformio\packages\framework-arduinoespressif32\cores\esp32/Udp.h:42:1: error: expected class-name before '{' token
In file included from C:\Users\Hamid\.platformio\packages\framework-arduinoespressif32\cores\esp32/Arduino.h:154:0,
C:\Users\Hamid\.platformio\packages\framework-arduinoespressif32\cores\esp32/HardwareSerial.h:54:1: error: expected class-name before '{' token
*** [.pio\build\esp32dev\src\main.cpp.o] Error 1
In file included from C:\Users\Hamid\.platformio\packages\framework-arduinoespressif32\cores\esp32\Arduino.h:151:0,
from C:\Users\Hamid\.platformio\packages\framework-arduinoespressif32\cores\esp32\Esp.cpp:20:
C:\Users\Hamid\.platformio\packages\framework-arduinoespressif32\cores\esp32\Client.h:27:1: error: expected class-name before '{' token
In file included from C:\Users\Hamid\.platformio\packages\framework-arduinoespressif32\cores\esp32\Arduino.h:153:0,
C:\Users\Hamid\.platformio\packages\framework-arduinoespressif32\cores\esp32\Udp.h:42:1: error: expected class-name before '{' token
In file included from C:\Users\Hamid\.platformio\packages\framework-arduinoespressif32\cores\esp32\Arduino.h:154:0,
from C:\Users\Hamid\.platformio\packages\framework-arduinoespressif32\cores\esp32\FunctionalInterrupt.cpp:9:
from C:\Users\Hamid\.platformio\packages\framework-arduinoespressif32\cores\esp32\IPAddress.cpp:20:
from C:\Users\Hamid\.platformio\packages\framework-arduinoespressif32\cores\esp32\IPv6Address.cpp:20:
*** [.pio\build\esp32dev\FrameworkArduino\FunctionalInterrupt.cpp.o] Error 1
from C:\Users\Hamid\.platformio\packages\framework-arduinoespressif32\cores\esp32\MD5Builder.cpp:19:
In file included from C:\Users\Hamid\.platformio\packages\framework-arduinoespressif32\cores\esp32\MD5Builder.cpp:20:0:
C:\Users\Hamid\.platformio\packages\framework-arduinoespressif32\cores\esp32/MD5Builder.h:55:20: error: 'Stream' has not been declared
bool addStream(Stream & stream, const size_t maxLen);
C:\Users\Hamid\.platformio\packages\framework-arduinoespressif32\cores\esp32\MD5Builder.cpp:56:28: error: 'bool MD5Builder::addStream' is not a static data member of 'class MD5Builder'
bool MD5Builder::addStream(Stream & stream, const size_t maxLen)
C:\Users\Hamid\.platformio\packages\framework-arduinoespressif32\cores\esp32\MD5Builder.cpp:56:28: error: 'Stream' was not declared in this scope
C:\Users\Hamid\.platformio\packages\framework-arduinoespressif32\cores\esp32\MD5Builder.cpp:56:37: error: 'stream' was not declared in this scope
C:\Users\Hamid\.platformio\packages\framework-arduinoespressif32\cores\esp32\MD5Builder.cpp:56:45: error: expected primary-expression before 'const'
C:\Users\Hamid\.platformio\packages\framework-arduinoespressif32\cores\esp32\MD5Builder.cpp:56:64: error: expression list treated as compound expression in initializer [-fpermissive]
C:\Users\Hamid\.platformio\packages\framework-arduinoespressif32\cores\esp32\MD5Builder.cpp:57:1: error: expected ',' or ';' before '{' token
*** [.pio\build\esp32dev\FrameworkArduino\IPAddress.cpp.o] Error 1
*** [.pio\build\esp32dev\FrameworkArduino\IPv6Address.cpp.o] Error 1
from C:\Users\Hamid\.platformio\packages\framework-arduinoespressif32\cores\esp32\Print.cpp:28:
*** [.pio\build\esp32dev\FrameworkArduino\MD5Builder.cpp.o] Error 1
In file included from C:\Users\Hamid\.platformio\packages\framework-arduinoespressif32\cores\esp32\Esp.cpp:33:0:
*** [.pio\build\esp32dev\FrameworkArduino\Print.cpp.o] Error 1
*** [.pio\build\esp32dev\FrameworkArduino\Esp.cpp.o] Error 1
==================================================================== [FAILED] Took 3.29 seconds ====================================================================
The terminal process "C:\Users\Hamid\.platformio\penv\Scripts\platformio.exe 'run'" terminated with exit code: 1.
